Matsushita and B16 swap...... Or should I do this insteaD?
Old Jun 10, 2008 | 01:09 PM
JUN.'s Avatar
Default Matsushita and B16 swap...... Or should I do this insteaD?
My car came with the Matsushita compressor/lines/etc.... I did a b16A swap and I know that I would have to buy the Hasport bracket to make it fit but I did a search and found out that some people is having problems with the fitment......
Does any one knows if this is true?
I can get a b18A compressor and bracket but I know that the lines wont fit and I dont know how is the fitment either..... Has anyone done this?
Old Jun 10, 2008 | 03:39 PM
zrickety's Avatar
Default Re: Matsushita and B16 swap...... Or should I do this insteaD? (JUN.)
bump for you my friend...i am in the process of getting a/c parts for my b16 swap. i intend to use all integra parts up to the firewall and adjust to fit. i would like to know the answer to your questions as well
Old Jun 10, 2008 | 03:51 PM
JUN.'s Avatar
Default Re: Matsushita and B16 swap...... Or should I do this insteaD? (zrickety)
I might just buy the hasport bracket, but I dont know if the sanden version works for the Matsushita version...... Maybe they are the same brackets but multiple holes to match your compressor?
Old Jun 11, 2008 | 05:00 PM
JUN.'s Avatar
well I went to the junk yard and got a pr3 AC bracket for 20 bucks...... I installed it in my car and it only bolts to 2 holes at the bracket... but its pretty strong.... I might have to hammer the crossmember a little bit for clearance....
Me 1
hasport 0
Old Jun 11, 2008 | 06:18 PM
Loaded Butane's Avatar
I just got the bracket from HASport. I got it from nolimit in the marketplace. I couldnt tell you about fitment yet because I havent gotten that far into my swap yet.
System-7
Mar 23, 2006 05:40 AM
zexhuffer
13
Jan 30, 2006 07:58 PM
Jonnyr4c
Nov 20, 2004 12:42 PM
bullock
Sep 12, 2004 07:09 PM
91hatch_on17's
Mar 25, 2004 06:01 PM
