No spark after charging dead battery
Old Jun 10, 2008 | 10:24 AM
driter's Avatar
Default No spark after charging dead battery
Accord was running great. I parked it for several weeks and the battery ran completely down. I recharged the battery without taking off battery cables. The battery is now recharged but I get no spark at plugs. Timing belt and fuel check ok. What have I done to the spark or merely a coincidence after charging battery?
Old Jun 12, 2008 | 11:49 AM
driter's Avatar
This is a '92 Accord. Does anyone know if the main relay could cause this problem or does it only control the fuel pump?
Old Jun 12, 2008 | 12:14 PM
NeKe1point0's Avatar
Default Re: (driter)
so the car is turning over but just no spark right ? did you touch any grounds ? if all grounds are good, id resistence check the coil, if that checks out ok next is the distributor. give me a sec and ill look up which points on the coil to test.
Old Jun 12, 2008 | 12:24 PM
Default Re: (NeKe1point0)
Old Jun 12, 2008 | 04:29 PM
driter's Avatar
Thanks for the reply. Yes the car is turning over fine, it just has no spark. All grounds are good. I checked the coil resistance and both primary and secondary check within limits. This is an EX with the internal coil. If it turns out I need a new distributor are the aftermarket ones OK or do I need to go with an OEM?
Old Jun 12, 2008 | 04:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driter &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply. Yes the car is turning over fine, it just has no spark. All grounds are good. I checked the coil resistance and both primary and secondary check within limits. This is an EX with the internal coil. If it turns out I need a new distributor are the aftermarket ones OK or do I need to go with an OEM?</TD></TR></TABLE>
O ok i took a guess whether it was ex/lx. I bought mine from dist king off ebay,I DONT reccomend them at all. I went through hell with them to get the right dizzy. They had what was supposed to be mine advertised wrong. it was a pain to say the least. Once i finally got the "correct" dizzy the connector needed modding to snap in. on the other side i have read tons of post where others here have had no probs at all with them.
If i could do it over i woulda bought from Honda just for the peace of mind.
Jeremy Dunn
Aug 31, 2017 04:48 PM
H22Ej1
Nov 27, 2006 12:10 PM
1baddcivicsi
26
Oct 13, 2006 04:17 PM
EeeJayEight
Dec 16, 2004 10:31 PM
pickleboy8507
Mar 27, 2004 04:11 PM
