S2K Oil Filter on BB6
Old Jun 10, 2008 | 09:45 AM
Arsenal's Avatar
Default S2K Oil Filter on BB6
Anyone have experience with using an OEM S2K filter on a BB6 Prelude?
Changing the oil tomorrow, and have a spare one left from out old S2k (bought a case of them when we had it)
I assume that since both are 2.2L it would be okay? Or does the H series have higher oil pressures?
Old Jun 10, 2008 | 09:49 AM
vinuneuro's Avatar
Default Re: S2K Oil Filter on BB6 (Arsenal)
There's no issue. This was the oil filter Honda used before switching to the small ones.
Old Jun 10, 2008 | 11:17 AM
md23vtec's Avatar
Default Re: S2K Oil Filter on BB6 (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have experience with using an OEM S2K filter on a BB6 Prelude?
I assume that since both are 2.2L it would be okay? Or does the H series have higher oil pressures?</TD></TR></TABLE>
Yes you can use an S2000 filter on your H22/H23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">There's no issue. This <U>was the oil filter Honda used before switching to the small ones</U>.</TD></TR></TABLE>
Actually no they were not the same. The old Honda filter was slightly smaller then the S2000 filter and had a different part #.
Old Jun 10, 2008 | 11:19 AM
vinuneuro's Avatar
Default Re: S2K Oil Filter on BB6 (md23vtec)
Hmm, good to know. Is there an oil pressure difference between the new small Honda filter and the s2k unit?
Old Jun 10, 2008 | 11:33 AM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, good to know. Is there an oil pressure difference between the new small Honda filter and the s2k unit?</TD></TR></TABLE>
I have been running the S2000 oil filter for years now. I do have a couple more pounds of oil pressure at idle using the bigger filter. But I would "think" it would be the other way around because the smaller filter has less oil capacity. I did this back to back in warmed up conditions with the same results ( didn't have anything better to do that day at work )
Old Jun 10, 2008 | 12:09 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
I have been running the S2000 oil filter for years now. I do have a couple more pounds of oil pressure at idle using the bigger filter. But I would "think" it would be the other way around because the smaller filter has less oil capacity. I did this back to back in warmed up conditions with the same results ( didn't have anything better to do that day at work ) </TD></TR></TABLE>
The oil pressure sensor might be after the filter so the smaller filter probably creates a pressure loss due to the lower flow.
Old Jun 10, 2008 | 06:39 PM
Mykizism's Avatar
very good to know!
Old Jun 10, 2008 | 07:20 PM
prelude_93vtec's Avatar
I think they both have same part #'s
Old Jun 10, 2008 | 07:38 PM
DfwBB6's Avatar
Default Re: S2K Oil Filter on BB6 (prelude_93vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">I think they both have same part #'s</TD></TR></TABLE>
Maybe the old one the new ones dont. Honda S2000 Part# 15400-PCX-004 and Prelude is part# 15400-PLM-A02, the older versions of the prelude were 15400-P0H-305 they had a smaller outside diameter.
Old Jun 10, 2008 | 07:49 PM
vinuneuro's Avatar
Default Re: S2K Oil Filter on BB6 (DfwBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DfwBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe the old one the new ones dont. Honda S2000 Part# 15400-PCX-004 and Prelude is part# 15400-PLM-A02, the older versions of the prelude were 15400-P0H-305 they had a smaller outside diameter.</TD></TR></TABLE>
So was the old Prelude filter slightly smaller than the s2k filer but larger than the current standard one?
Old Jun 13, 2008 | 07:16 PM
O sorry didn't realise you guys were talking about OEM. When I checked pepboys, the mobil1 oil filters were the same part #;s.
Old Jun 13, 2008 | 08:01 PM
md23vtec's Avatar
So was the old Prelude filter slightly smaller than the s2k filer but larger than the current standard one?</TD></TR></TABLE>
100% correct
Old Jun 13, 2008 | 08:14 PM
russlan44's Avatar
so is there any point of s2k filter, any cons and pros? i know its sligtly larger
Pnoyej6
Sep 27, 2006 05:30 AM
EG2Driver
23
Sep 15, 2006 09:22 AM
lowlavar
Honda Civic (2006 - 2015)
Sep 11, 2006 07:27 PM
JDMInspired
Honda Civic (2001 - 2005)
10
Jun 7, 2006 05:13 PM
AznMTboy
Jan 5, 2005 09:20 PM
