High Beam light on gauge cluster is on for my low beams. HOw do i fix that?
Old Jun 10, 2008 | 08:19 AM
jonaldjenkins's Avatar
Default High Beam light on gauge cluster is on for my low beams. HOw do i fix that?
basically my gauge cluster is switched and says my high beams are on even if its my lows and when i switch to my highs, it thinks its my lows. how do i fix that? i have a 99 ek hatch with an si gauge cluster. thanks in advance!!
Old Jun 10, 2008 | 09:52 AM
Relic1's Avatar
aftermarket projector headlights?
you have the high and low plugs switched on the headlights.
Old Jun 10, 2008 | 01:14 PM
no theyre not projectors. stock headlights.
Old Jun 10, 2008 | 02:54 PM
Relic1's Avatar
turn the headlights off, pull back on the headlight switch. Does the high or low beams turn on?
It should be the high beams (and high beam indicator) if it's the low beams something is switched. (high/low wires)
If it's the high beams then something is screwed up in the switch wiring.
Old Jun 10, 2008 | 02:58 PM
batallic's Avatar
do u HAVE HIDs
Old Jun 10, 2008 | 03:13 PM
yeah i think something is wrong with the wiring somewhere. i dont have hids though.
James_Starks
21
Oct 16, 2022 12:23 PM
JJT211
Apr 21, 2013 10:46 AM
EFresh
10
Apr 10, 2013 07:39 AM
mtny
Aug 1, 2007 07:09 PM
Jos3ph
Feb 10, 2006 12:30 PM
