Power Door Locks Not Working
i have checked the fuse under the hood its good but only the drivers door lock will open when i use the keyless entry or use the master lock switch on the drivers door it started of with just the back drivers door lock would not work then the other back door now two days ago the passenger door lock stoped working all the locks work only manually any suggestions as to what could fix this?
You need a new actuator in the driver door, considering the other doors are only going to open accordingly to the driver door. So if the driver door is jammed, all the doors(to the cars computer) are jammed also. Fix your driver door actuator!
SOmeone correct me if I'm wrong.
YEAH YOU ARE CORRECT. THE DRIVER DOOR CONTROLS EVERYTHING. BUT IT WOULDN'T HURT TO CHECK THE OTHER DOORS. MY BOYS' CAR DID THAT **** TOO SO WE REPLACED THE MAIN UNIT ON THE DRIVER DOOR BUT THAT OTHER DOOR WAS STILL NOT WORKING SO WE TOOK THE PANEL OFF AND SAW THAT THE METAL DEAL WAS NOT ATTACHED TO THE DOOR LOCK SOME HOW. BUT HOME BOY IS RIGHT ABOUT REPLACEING THE UNIT ON THE DRIVER DOOR.
nismogrendel
Jan 26, 2013 07:34 PM
m.glisson003
Aug 7, 2011 12:36 PM
