change engine
Old Jun 10, 2008 | 05:40 AM
thunderboy's Avatar
Default change engine
I have a b18c broken in my car and I wanna put a new engine.the old gearbox is ok what to do to change the engine??
Old Jun 10, 2008 | 06:07 AM
hatchling37's Avatar
Default Re: change engine (thunderboy)
Very straight forward, but a little complicated for the amateur. Basically, you go through and unclip the harness, pull tranny, then pull the motor. Unless you have mad dog access to hoist and all the conveniences that a shop offers. Then you can drop the engine and tranny together.
Old Jun 10, 2008 | 12:12 PM
Jimmy's Avatar
Global Moderator
Default Re: change engine (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Very straight forward, but a little complicated for the amateur. Basically, you go through and unclip the harness, pull tranny, then pull the motor. Unless you have mad dog access to hoist and all the conveniences that a shop offers. Then you can drop the engine and tranny together. </TD></TR></TABLE>
Yes, Best investment i've made was a engine hoist.. I bought one from harbour freight for 96 bucks..
Old Jun 10, 2008 | 06:14 PM
sjbmx's Avatar
if you have to ask its to much for you..
Old Jun 10, 2008 | 07:11 PM
jakeiscool's Avatar
Banned
Default Re: change engine (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjbmx &raquo;</TD></TR><TR><TD CLASS="quote">if you have to ask its to much for you.. </TD></TR></TABLE>
dont listen to this guy^^^ he is just going around making pointless posts to raise his count.
swapping the old motor out, and putting a new one in isnt really that hard since you are using the same motor (same engine code not literally the same motor)
unclip the harness, disconnect the rad hoses and the heater core hoses, throttle cable, fuel line, exhaust, mounts and pull it out. good luck
Old Jun 10, 2008 | 10:39 PM
sjbmx's Avatar
Quote, originally posted by sjbmx »
no! that was a legit post! along with all my others
Old Jun 10, 2008 | 11:38 PM
Jimmy's Avatar
Global Moderator
no! that was a legit post! along with all my others</TD></TR></TABLE>
No that wasn't a legit post
I would consider it pretty damn rude..
Everyone has to start sometime.. How would you feel making a post asking someone a question and someone basically calling you a dumbass.. You know like when you asked if you could put front brakes on the rear..
To the original poster:
I would suggest you picking up a helms manual for your specific model vehicle it will help alot.. On step by step and illustrations.. If you are slightly mechanically inclined or knowledgeable you will be able to do it no problem.
Old Jun 12, 2008 | 01:21 AM
sjbmx's Avatar
thats not what i meant at all. i just meant it is a bit complicated and he should read up a bit on it. in retrospect it does seem rude though. and the front to rear breaks was just me being curious, i dont think anyones ever covered that.
Old Jun 12, 2008 | 08:44 AM
HONDRETTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thunderboy &raquo;</TD></TR><TR><TD CLASS="quote">I have a b18c broken in my car and I wanna put a new engine.the old gearbox is ok what to do to change the engine??</TD></TR></TABLE>
before you go replacing your motor, would u mind telling us what is wrong with it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
I would suggest you picking up a helms manual </TD></TR></TABLE>
Old Jun 12, 2008 | 09:10 AM
Rickdrizzle's Avatar
Mind telling us what's wrong with the engine first? Also, how much are you getting the long block for? If it's over a grand or so, and the engine you already have isn't that messed up, then you might as well just rebuild it with some quality parts.
Old Jun 12, 2008 | 06:16 PM
thunderboy's Avatar
Default Re: (Rickdrizzle)
piston hit one valve and broke the head and the block they call it over rev!!!
Old Jun 12, 2008 | 07:24 PM
Default Re: (thunderboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thunderboy &raquo;</TD></TR><TR><TD CLASS="quote">piston hit one valve and broke the head and the block they call it over rev!!!</TD></TR></TABLE>
wait, so the head and block ITSELF is messed up?
If the block itself is still fine, I say you should resleeve it and get forged rods and pistons. Beef up that block so it'll never happen again.
qazaq
Jan 23, 2009 05:01 PM
brodyl05
Mar 25, 2007 06:18 AM
alupso
24
Jan 24, 2006 12:08 PM
GruvyTune
Jul 1, 2002 09:02 PM
