Driver door cannot open.
Old Jun 9, 2008 | 09:37 PM
TopRamen's Avatar
Default Driver door cannot open.
1990 Honda Accord Se.
Several minutes prior door was mechanically functioning.
As of now, I cannot open my driver door....any thoughts?
Old Jun 9, 2008 | 10:57 PM
-JSpecEk*9-'s Avatar
Default Re: Driver door cannot open. (TopRamen)
Old Jun 10, 2008 | 02:54 AM
BBallz24's Avatar
Default Re: Driver door cannot open. (-JSpecEk*9-)
the latch must have come off inside the door or something?
Old Jun 10, 2008 | 04:28 PM
The_Caged_Bird's Avatar
Default Re: Driver door cannot open. (BBallz24)
It won't open by using either handle?
If so then it's the latch itself. That will be fun to replace, it will be even funner getting the door to open so you can replace said latch.
Good luck!
Old Jun 10, 2008 | 06:52 PM
Maachan513's Avatar
Default Re: Driver door cannot open. (The_Caged_Bird)
I am new to this 93 LX. This car also had non-opening-door with previous owner. Him and his freind somehow opened the door. They must have busted mechanism because they had to buy used door to replace it.
I see many scars near latch mechanism.
Old Jun 11, 2008 | 04:40 PM
Mr Yamada's Avatar
Remove the drivers seat, then the door panel.
You can then try all the linkage you can move to try to open the door.
If you have to drill the latch from inside the door this picture will show you where to drill so as to trip the latch.
Drill at a slight downward angle,after you go thru the first layer
Keep your shoulder pushing the door so it will open when you trip the latch.
the latch will need to be replaced.
Mychal71
Mar 20, 2022 01:32 PM
sranauta
Honda CR-V & Element
Jul 19, 2015 11:00 AM
jtwellner
Dec 5, 2012 04:00 PM
mataliandy
Jul 12, 2010 06:24 PM
suhteevin
Jan 6, 2009 09:04 PM
