Transmission won't go into gear.
just did a b series swap and now the transmission wont go into gear. could it be the slave cylinder or fork that's doing that? cause there isn't a lot of pressure on the clutch pedal. could it be the clutch not being on tight enough and not engaging? it's not making any odd noises. please help me. thanks
is the trans you put in cable or hydro?If cable did you use a cable to hydro convertion kit. If hydro did you make sure that the throw out bearring was installed correctly on the fork? Did you put the push rob in place when you installed the slave cylinder? Do you have any leaks?
ditto. same thing happened in my accord and it was so bad that the throw out bearing seized and i had to replace the whole transmission
red_EF9Si
Transmission & Drivetrain
22
Mar 31, 2012 10:35 PM
ED6JDM
Jul 10, 2007 06:43 PM
1SIKEF8B20VTEC
Oct 5, 2005 04:44 PM
