New struts and springs??
Old Jun 9, 2008 | 07:09 PM
428saleen's Avatar
Default New struts and springs??
I am needing to replace my struts and shocks on my 94 Honda Civic hatchback. I also would like to lower it at the same time. My question is what would be the best way to go about this? What would be the best product to get while replacing the shocks and struts and lowering(not slammed) also would like to add some 15" wheels and new tires... Any thoughts?
Old Jun 10, 2008 | 07:46 AM
428saleen's Avatar
Default Re: New struts and springs?? (428saleen)
anyone...
Old Jun 10, 2008 | 08:04 PM
cmgorman94's Avatar
koni yellows with either ground control coilovers or eibach pros.
Old Jun 10, 2008 | 09:10 PM
Agent_EM1's Avatar
Default Re: (cmgorman94)
What do you intend to use it for? For daily driving, a good budget set up are the Tokoco blues with just about any name brand lowering spring... If you want to spend a good chunk, then a good set up would be Ground COntrol Sleeves over Koni Yellows.
Old Jun 10, 2008 | 09:26 PM
1995Civic's Avatar
Default Re: (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 428saleen &raquo;</TD></TR><TR><TD CLASS="quote">I am needing to replace my struts and shocks on my 94 Honda Civic hatchback. I also would like to lower it at the same time. My question is what would be the best way to go about this? What would be the best product to get while replacing the shocks and struts and lowering(not slammed) also would like to add some 15" wheels and new tires... Any thoughts? </TD></TR></TABLE>
Shocks and struts are considered the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">What do you intend to use it for? For daily driving, a good budget set up are the Tokoco blues with just about any name brand lowering spring... If you want to spend a good chunk, then a good set up would be Ground COntrol Sleeves over Koni Yellows. </TD></TR></TABLE>
Suspension really does depend on what you're looking to do with it. However, Tokico Blues are just a stock replacement, and cannot be adjusted. I would suggest a Koni/GC setup as well. Koni's are 5-way adjustable and have a lifetime warranty.
Old Jun 11, 2008 | 07:26 AM
mateo5046's Avatar
Default Re: (1995Civic)
Tociko Illuminas with Skunk2 lowering springs. Good ride with ajustability and the drop leaves you about a 1 finger gap.
Old Jun 12, 2008 | 06:47 AM
428saleen's Avatar
Thanks for the information!!
slh2504
Suspension & Brakes
Mar 14, 2009 07:37 AM
JAYB90
21
Jan 31, 2009 11:20 PM
rare*style
Oct 13, 2008 07:27 PM
rkn527
20
Nov 11, 2003 12:04 PM
Tad
Jul 3, 2003 03:41 PM
