Engine not starting
Old Jun 9, 2008 | 06:30 PM
phagelman's Avatar
Default Engine not starting
Driving down the interstate my 1992 Accord LX died last week. Started by replacing fuel filter, no fix. Replaced fuel pump, no fix. Replaced Rotor/Distributor cap/spark plugs, no fix. Replaced Coil, no fix.
Engine turns and gas is getting into the cylinders but no start. Tested Power output from coil and it is giving me 0 spark. Can't find a fuse or relay that would correspond to the coil/starter. Maybe some fused wiring or something?? About to break down and take it to a shop. But any suggestions before I do??
Thanks in advance.
Old Jun 9, 2008 | 06:33 PM
92JDMCB7's Avatar
Default Re: Engine not starting (phagelman)
check your main relay. cb's are known for bad main relays
Old Jun 9, 2008 | 06:34 PM
phagelman's Avatar
Default Re: Engine not starting (92JDMCB7)
Relay looks fine. No burning/breaking in it at all. Looks clean. (Could it still be bad??) Also the fuel pump is working for sure.
Old Jun 9, 2008 | 06:51 PM
92JDMCB7's Avatar
so i assumed you took it out and checked all the solderings on the bak side for splits and breaks?
Old Jun 23, 2008 | 10:35 AM
hdstro's Avatar
I am having the same problem with my 94 Accord.
I have changed the folloing;
Main Relay (MR)
Distributor
Ignition Switch
3 Wiring Harness to stearing wheel
I even resoldered the old MR and same intermittant failure
Before today i could hear the MR click after siting in the heat several minuted and then I would be able to start the car. But, now it is just turning over
Please help
Old Jun 23, 2008 | 03:39 PM
Hardenbrook32's Avatar
I have the same problem with my 93 Accord. I am looking for a fix but, in the mean time i turn the key until i see the check engine light. Wait for it to go off. Then turn the key a little until you hear a click. Finally turn the engine over and hopefully it will start. It works on my car. Sometimes I have to try it a few times.
Scott Kevern
Jul 25, 2016 11:12 AM
OkayTrash
Dec 30, 2011 09:11 AM
culinaryjeremy
Mar 21, 2009 07:15 AM
black cx
Jan 28, 2008 11:18 AM
Ep1dem1c
Jul 3, 2007 06:49 AM
