Stripped Head on tranny
my clutch just went out on me and I was removing my tranny when i ended up stripping the head of the bolt pretty bad i bought a gator grip socket and still nothing. it didnt catch,,,,,, Its the last bolt on the tranny and the reason it got stripped was because that thing was somehow tightened by the incredible hulk lol. na but really no joke it bad. its the bolt that is next to closest to the dizzy on the top ill try to post a pic when i get home 2night. H22a with h22a tranny in a accord 93 5speed.... help please.
I would try one of these from Sears...
http://www.sears.com/shc/s/p_1...2000P
I have used them a couple times and they work good.
use exactly what touring accord posted. Or if you think you can slide the tranny away from the block just cut the head off and then when the trans is out grab it with a pair of vice grips and loosen it.
thanks for all your input i went with what you said Touring an picked up that set at Sears, my bolt was very bad almost completely round and also tight as hell.....
I sprayed some wd-40 an let it sit over night and this morning I went to remove it with that set and i was surprised it grabbed very very good and i used a breaker bar an i got it out!!!!!!!!YES. thanks again im gonna finish dropping the tranny here in a bit. Any suggestions on a new clutch cause that's what im replacing, I currently have a ACT stage 2 its a 4 puck i believe ill find out when i drop the tranny i had the clutch for about 3 years and it finally went bad I cant put it in gear at all. I just hope its the clutch and not the tranny...
Modified by EJ6SON at 1:12 PM 6/10/2008
glad it worked out for you.
I don't usually care for most of those bolt-out and screw-out deals but these have worked each time I've needed to use them.
also do you have any tips when dropping the tranny after i took off the boltthe tranny didnt move a bit i tried wedging it off but no luck i have a jack under it to let it down slowly .....also do you have to take off the starter from the tranny when you removing the tranny or can it stay on? and also one more question when i took off the axles from the tranny no tranny fluid spilled out? im assuming that a very bad thing
