Hi, new OLD user here :)
So I am taking bets on my qm time here. Havent ran it yet.
1989 honda civic hatch
lotsa dents (aerodynamically placed speed dents)
d15b1 block
bore .30
some flat piston polished pistons and some sort of rings (i forgot)
if it helps compresion test was 220 psi across
polished and balanced rods and crank
Hi strength rod bolts (again forgot)
HP rod berings, stock Crank berrings (at that time no hp crank berrings avail)
d16y7 head
polished ports
edges of head domes bored between the closest of valve to mating suface.
polished domes ,milled mating edges around dome.
Nippon Racing Stage 2 Camshaft
AEM gear at 2 deg ReTaRd
that flat headgasket for that year that was 2 metal strips with cheese
Jackson Racing supercharger 8psi
new supercharger goo
370 cc Injectors
MSD 6al on a si distributor
1989 Acura integra AUTOMATIC ECU
4spd Manual honda tranny
exhaust 4 2 dual out with harley baffles at 1 3/4in for backpressure
mobil 1 since birth eng and trans.
and other stuff i forgot..
Modified by Livengood at 4:56 PM 6/9/2008
d15b1 block
bore .30
d16y7 head
polished ports
370 cc Injectors
X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff @ Tempest »</TD></TR><TR><TD CLASS="quote">
projektvtec
Northeast (Sales)
42
Jul 27, 2006 05:39 PM
projektvtec
May 25, 2006 08:51 AM
