Fan not turning on need some help!!!!!!
Old Jun 9, 2008 | 02:35 PM
94egR's Avatar
Default Fan not turning on need some help!!!!!!
Need some advise the fan on my eg does not want to turn on any suggestions?
Old Jun 13, 2008 | 01:00 PM
vtecb18c's Avatar
Default Re: Fan not turning on need some help!!!!!! (94egR)
does the car start to overheat at idle? could be your fan relay fuse or thermostat
Old Jun 13, 2008 | 02:09 PM
freshdaily's Avatar
Default Re: Fan not turning on need some help!!!!!! (vtecb18c)
if its your cooling fan, get two wires and run power directly to it from your battery, if it doesnt come on its OUT! if it does, then the problems else where, start at the fuses! or your temp switch at the thermostat could be out!
Old Jun 13, 2008 | 02:52 PM
instrument's Avatar
http://www.tegger.com/hondafaq...x.htm
mmm.yeah..dirty..
Old Jun 15, 2008 | 05:50 PM
vtecb18c's Avatar
Default Re: (instrument)
how did you make out did you try anything?
Old Jun 15, 2008 | 06:16 PM
h2392si's Avatar
Default Re: (vtecb18c)
Could be a lot of things. First off is it overheating? Second check the thermostat. fan switch, fan relay, radiator cap, etc. Try the small things first and get back to us.
Old Jun 16, 2008 | 11:18 AM
r33dm0n3y's Avatar
Default Re: (h2392si)
check your thermoswitch. it's housed right on the side of the thermostat housing. my fan doesn't work either, I checked the thermoswitch (just need a paperclip. pull the plug off the thermoswitch and complete the circuit with your car running.) i'll bet you 5 bucks thats the prob. mine doesn't overheat so i haven't worried about it much.
fatl13ert
Oct 22, 2012 12:41 AM
19 crx 89
10
Aug 26, 2010 12:38 PM
xTomei
10
Jun 7, 2010 06:02 PM
vti444
Aug 22, 2007 08:51 AM
wsiracerz
Jun 4, 2004 12:30 AM
