94 Accord passenger power window.
Old Jun 9, 2008 | 02:24 PM
norrisboat's Avatar
Default 94 Accord passenger power window.
Hi all,
Im stumped. I cant figure out why passenger side accord coupe window will not go up or down. Drivers side works fine. There is no noise coming from the regulator signifing it has power.
I tested the switch before removing anything. I had power to the switch before I did anything. I figured since I have power to the switch and no noise from the motor by activating the switch, that the motor must be bad.
I ordered and plugged in the new motor. I didnt install it yet because I wanted to see if it was the true problem. I get no movement of the slide or any noise from the motor.
Now I notice I no longer have and power to the switch using my multimeter. engaged or disengaging the switch i dont recieve any power.
I ordered a new switch knowing its probably not the problem.
Install the switch no movement of the slide/regulator.
I swapped the cooling fan relay with the power window relay since they are the same.
Still no movement from the slide/regulator.
Checked fuses. They are all good.
Drivers side window controller also doesnt power the passenger side window. The drivers side window works fine.
Does anyone have an idea why its not working? I had power to the switch before replacing the regulator and now i dont. Does anyone understand what else could have gone wrong?
Thanks,
Norrisboat
Modified by norrisboat at 5:53 PM 6/9/2008
Old Jun 9, 2008 | 06:54 PM
norrisboat's Avatar
Default Re: 94 Accord passenger power window. (norrisboat)
anyone?
Old Jun 9, 2008 | 07:10 PM
TheMuffinMan's Avatar
He knows where you live!
Wiring?
Old Jun 10, 2008 | 03:17 PM
norrisboat's Avatar
Default Re: (TheMuffinMan)
I was hoping to there would be some holy grail problem instead of seaching the wires for a bad ground. If im going to resort to the wiring i think ill just take it to someone to fix unless someone else has suggestions. Thanks for the help.
Old Jun 10, 2008 | 03:48 PM
norrisboat's Avatar
Default Re: (norrisboat)
Ok, so i goofed. I used a bad ground when i was measuring for power at the switch and the motor.
I have power to the switch. I also have power to the wiring harness connection(where the regulator plugs into) when clicking the switch one direction. The other direction on the switch doesnt produce a voltage result(im assuming its because its for down window operation, not sure though).
Did I get a dead on arrival motor? What else could it be?
Thanks, Norris
Old Jun 10, 2008 | 04:37 PM
The_Caged_Bird's Avatar
I'm not sure here, as I've never had this problem in a Honda but I know that in my 'vette the motor is grounded to the frame of the door. It can be a functioning motor but if it isn't sitting on the metal ground then it won't work. Try installing the motor, if it doesn't work after that I'd double-check all fuses, and go from there.
kwae
Sep 29, 2017 10:32 AM
motorsports_3
Aug 15, 2010 12:25 PM
drew and not u
Jun 28, 2008 06:56 PM
scooterguy
Nov 26, 2005 02:35 PM
