NO engine check lights But wont start help ME!!!
Old Jul 16, 2002 | 10:39 PM
nosmas's Avatar
Default NO engine check lights But wont start help ME!!!
just installed a b16a2 but wont start it cranks though but wont start what could it be? distributor?
Old Jul 16, 2002 | 10:43 PM
salbaje's Avatar
Default Re: NO engine check lights But wont start help ME!!! (nosmas)
did you check for sparks? and grounds??
Old Jul 16, 2002 | 11:55 PM
sparkz's Avatar
check ecu conenctions and make sure ecu fuse is ok. then check main relays. check for spark and fuel
Old Jul 17, 2002 | 04:58 AM
Mikey3000's Avatar
Default Re: NO engine check lights But wont start help ME!!! (sparkz)
also check to see if you have all your sensor connectors on the correct sensors. oh and check your firing order.
Old Jul 17, 2002 | 05:55 AM
brcivic411's Avatar
Default Re: NO engine check lights But wont start help ME!!! (Boss Hogg)
this is dumb.. but do you have enough fuel? did you pull the fuel pump fuse and forget to put it in? does the fuel system have pressure?
KeeshaunaG7
Nov 21, 2014 06:36 PM
Felipe_Rdz
May 8, 2013 02:27 PM
91rexhf
Dec 29, 2008 11:43 PM
sipolt89
Dec 9, 2007 10:14 AM
Gumbey75
Feb 26, 2005 10:32 PM
