alternator removal DA
Old Jun 9, 2008 | 12:13 PM
rivoe302er's Avatar
Default alternator removal DA
hey guys im removing my alternator so far i unbolted everything but i cant remove it from the vehicle is there a special way to remove either from the top or bottom i really need to resolve this in order to get to work, thnx for any input
Old Jun 9, 2008 | 01:56 PM
bnorth's Avatar
Default Re: alternator removal DA (rivoe302er)
never done it on my da but i did one recently on an ef and just pulled the master cylinder off the booster and it slid past without issue.
Old Jun 9, 2008 | 01:58 PM
Rainy City's Avatar
If it's stuck, tap on it lightly with a prybar/hammer combo. If it still doesn't budge, it may be you forgot a bolt.
Old Jun 9, 2008 | 03:16 PM
God-Driven's Avatar
there's 2 ways you can get it done, one is pulling off the drivers axle and get the alternator from the bottom or remove the master cylinder (if removing master cylinder make sure to bleed the brakes and inspect the rear seal to make sure that there is no fluid inside the booster) good luck.
Old Jun 9, 2008 | 06:04 PM
1990tegg's Avatar
yes it does come out without braking half of the car apart... the same hole you reach your oil filter from the bottom... just move it around... you may think it wont come out but it does... just be patient...
Old Jun 9, 2008 | 09:12 PM
mike g's Avatar
Default Re: (1990tegg)
if you take off the two large bolts i believe to the half shaft and move it/swivel it down, this also frees up some space. it should just slide out from the bottom.
Old Jun 10, 2008 | 01:49 PM
lovemyDC2's Avatar
strange as it sounds I had this same problem on my old 91, but I wiggled it out some how, yet a few years later on my 92 I had to pull the driver axel, I couldnt remember how the heck I got it out..
Old Jun 10, 2008 | 04:07 PM
Fern413's Avatar
Default Re: (lovemyDC2)
if you remove driver side axle....it would be much easier that way...thats how i did it to mine..g/l
Old Jun 10, 2008 | 04:30 PM
VTEC_Du_Ma_Mai's Avatar
Default Re: (Fern413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike g &raquo;</TD></TR><TR><TD CLASS="quote">if you take off the two large bolts i believe to the half shaft and move it/swivel it down, this also frees up some space. it should just slide out from the bottom.</TD></TR></TABLE>
i find this to be the easiest way to do it. just because you dont need to remove the axle and the alternator will still be able to drop down.
Old Jun 10, 2008 | 08:03 PM
rivoe302er's Avatar
Default Re:
LOL! YEAH I COULDNT DO IT SO I TOOK IT TOO THE MECHANICS AND AFTER CHECKING THE ALTERNATOR HE SLAPPED ME IN THE BACK OF THE HEAD BECAUSE I DIDNT CHECK EITHER THE ALTERNATOR OR THE BATTERY WITH MY VOLT METER LOL FUNNY THING IS THAT IT WAS JUST MY BATTERY WAS DEAD
Old Jun 17, 2008 | 02:35 AM
90drewski-da's Avatar
ya'll all are doing it the hard way just drop the motor mount it will come right out
Old Jun 17, 2008 | 05:28 AM
D-SOHC 05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990tegg &raquo;</TD></TR><TR><TD CLASS="quote">yes it does come out without braking half of the car apart... the same hole you reach your oil filter from the bottom... just move it around... you may think it wont come out but it does... just be patient... </TD></TR></TABLE>
Yes it does, took me about 10 minutes of moving it around to get it out of my buddy's car.
Old Jun 17, 2008 | 07:20 AM
garagekansai's Avatar
Default Re: (D-SOHC 05)
ok here is how you do it i can change them out in 15min now .
1. remove 3 14 mm bolts holding the half shaft
2. remove 4 10 mm bolts holding the steering rack skid plate
3. move half shaft to the left (as if you were going to take it out )
this will give you about 3-4 inchs of clearence
4. now take the alternator pully side down and rotate until it falls out .
to install the new one just follow directions in reverse
jeddy0120
Nov 8, 2007 06:55 PM
Jizzmaster Zero
16
Dec 21, 2005 02:02 PM
unknownhero16
Dec 27, 2003 05:41 PM
91 civic
Apr 22, 2003 03:38 PM
'88civic
Nov 3, 2002 06:51 AM
