another cam seal replacement question?!(part number?)
Hi. I have 94 Integra LS and need to replace the cam seal. Is 12513-P72-003 the right part number? I looked up the part online and 94-95 seems to have diff part number(12513-P30-000) but I hear that the newer one has better design. I am just not certain if it'd fit 94....I figure it does since the motor is the same(right?)
I did search but did not turn up much on particular part number.
Also, how likely do the seal on the camgear side leak? Should I replace those while I am at it? Is it easy to take the gear off the camshafts??
thanks in advance.
thanks in advance.
Are you replacing the actual cam seals? or the cam plug? because the part numbers you posted are for the cam plug. The 1st part number you posted is for the 96+ Integra but im not sure if its any diffrent from the 94-95 Integra.
Modified by 94 IntegraLS at 2:56 PM 6/9/2008
Modified by 94 IntegraLS at 2:57 PM 6/9/2008
Cam plug...sorry. I am sure about the 94-95 vs 96+ that's why I am asking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 IntegraLS »</TD></TR><TR><TD CLASS="quote">Are you replacing the actual cam seals? or the cam plug? because the part numbers you posted are for the cam plug. The 1st part number you posted is for the 96+ Integra but im not sure if its any diffrent from the 94-95 Integra.
Modified by 94 IntegraLS at 2:57 PM 6/9/2008</TD></TR></TABLE>
Supposedly the new ones are better design than the old one...I am assuming they are the same since the billet ones are applicable to B18 in general...oh well it's only 7 bux each.
12513p30000, 12513p72003, 95, billet, cam, camam, honda, integra, integracamplug, odyssey, plug, replacement, seal, seals, set
