b20 vtec head gasket question
Old Jun 9, 2008 | 06:38 AM
japanstar_ef9's Avatar
Default b20 vtec head gasket question
i just finish building my b20 vtec and i did it with the full golden eagle kit.
the head had to come off and now i am ready to put it back on. My question is since i do not have the golden eagle b20 vtec head gasket any more do i need to modify the oem b20 head gasket, or is it good as is??? i still have the correct dowel pins and everything from the golden eagle kit. please help
Old Jun 9, 2008 | 10:58 AM
inspyral's Avatar
https://honda-tech.com/zerothread?id=2235725
You need to remove 2 rivets on the exhaust side of the head if you use a B20 gasket.
Old Jun 10, 2008 | 02:15 PM
gsrcrazy's Avatar
and correct the dowel pin holes on ur hg. the golden eagle dowel pins dont slide right in to the oem hg
Old Jun 11, 2008 | 08:26 AM
Golden Eagle's Avatar
Default Re: b20 vtec head gasket question (japanstar_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japanstar_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">i just finish building my b20 vtec and i did it with the full golden eagle kit.
the head had to come off and now i am ready to put it back on. My question is since i do not have the golden eagle b20 vtec head gasket any more do i need to modify the oem b20 head gasket, or is it good as is??? i still have the correct dowel pins and everything from the golden eagle kit. please help</TD></TR></TABLE> just give us a call and order the right gasket to make the b20 gasket work you would have to open up the dowel holes and remove rivets and at that the b20 gasket is the weakest gasket of all the oem gaskets and i do not sagest running it
XFactor27
Dec 31, 2011 10:44 AM
Civic483973
Jul 11, 2010 12:57 PM
95dc2teg
Dec 10, 2009 07:23 PM
ANNiHiLATORS
Nov 28, 2009 11:35 PM
adamrich33
Oct 12, 2008 04:54 PM
