solid cel after swap
did a gsr swap into my crx, running open header for now throwing a solid CEL. using a pr3 ecu had friend bring over his p28 same thing, thinking either bad o2 sensor or not sure.. LOL
the o2 is at least on or in the header right? hopefully u dont have it just hanging there.
http://www.c-speedracing.com/faq/06.php the FAQ area is your friend. good luck.
no no... u have to jumper the blue plug and then turn ur key to the on position and count the flashes. if it stays solid after you do this, then ur ECU is fried. but u need to get a numbered code to determine the issue. please READ that link... its really easy.
- BSeRiouS -
Honda S2000
Sep 6, 2006 10:09 PM
senpai
Jan 12, 2003 12:36 PM
