"Life Is Good": The $500.00 beach bomber
Take one cheap-o Sidekick and some craigslist tires, add some undercoatong, steel tube bumpers, fog lights, and elbow grease and you get a fun beach blaster. Lift kit is on backorder so I snapped a few pics anyway:
In case of emergency grab shovel :laugh: :
No carpet, just rhino lining:
Back seats are overrated:
From: huggin a corner in the right coast, PA, United states
Awesome beach buggy. I went to the drive on beach yesterday and would love to have had that thing.
<---------- Jealous
I totally want a Sidekick/Tracker to bum around the dunes with. That looks like it was a steal. Did you go with a Calmini lift?
Two things mine would get (other than a Calmini Lift):
Calmini Winch bumper
http://www.calmini.com
WARN M8000 Winch
http://www.warn.com
WARN M8000 Winch
http://www.warn.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thirty-Nine »</TD></TR><TR><TD CLASS="quote">
WARN M8000 Winch
http://www.warn.com
Talk about overkill for a 2400 pound vehicle. You need MAYBE a 6000 pound winch.
WARN M8000 Winch
http://www.warn.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squashman702 »</TD></TR><TR><TD CLASS="quote">
Talk about overkill for a 2400 pound vehicle. You need MAYBE a 6000 pound winch.</TD></TR></TABLE>
Well, I work for WARN and the formula is to take the gross weight of the vehicle multiplied by 1.5 to determine the minimum size winch. While an M6000 would be just fine, an M8000 is actually less expensive. The only difference between the two winches are the gear ratios anyways. The smallest truck winch WARN makes is rated at 6,000 lbs.
Well, I work for WARN and the formula is to take the gross weight of the vehicle multiplied by 1.5 to determine the minimum size winch. While an M6000 would be just fine, an M8000 is actually less expensive. The only difference between the two winches are the gear ratios anyways. The smallest truck winch WARN makes is rated at 6,000 lbs. </TD></TR></TABLE>
I've always heard that the rule of thumb was to multiply by 2.5 the vehicle weight. Since you work for Warn, want to hook me up with a winch?
I haven't heard that rule before. That'd mean that a Jeep Wrangler (JK Rubicon (manual) weighs 4,129 lbs.) shouldn't use anything less than a 10,322 lb. winch. Not true.
The gross weight of this vehicle is 5,000 lbs. Multiply that 1.5 and you get 7,500 lbs. WARN M8000 on up will work.
And unfortunately, I can't do the discount thing for anyone other than myself, and I have a Civic and a Yaris.
</TD></TR></TABLE>I haven't heard that rule before. That'd mean that a Jeep Wrangler (JK Rubicon (manual) weighs 4,129 lbs.) shouldn't use anything less than a 10,322 lb. winch. Not true.
cuz_ican
Sep 21, 2007 07:43 AM
