Will a main relay for a 90-91 be the same as my 89?
Old Jun 8, 2008 | 03:44 PM
89pre2.0si's Avatar
Default Will a main relay for a 90-91 be the same as my 89?
I've come down to a bad main relay giving me my problems....I think...I found a relay for sale on the web from a link on a different topic but it is labeled for a 90-91. It has the same numbers on it as the old one. Will this work?
Old Jun 15, 2008 | 06:14 PM
vtecb18c's Avatar
Default Re: Will a main relay for a 90-91 be the same as my 89? (89pre2.0si)
yup it'll work
Old Jun 15, 2008 | 09:48 PM
team123luder's Avatar
From any 88-91 Prelude, Civic, 86-93 integra they will all work from what I know.
Old Jun 15, 2008 | 11:42 PM
89pre2.0si's Avatar
Default Re: (team123luder)
That's awesome....now, any ideas where to get one cheap? anyone got an extra? it went from working sometimes to not working at all today. I got a HUGE interview this week and my car kinda needs to run. any clues at all?
Old Jun 16, 2008 | 06:57 AM
4WSi_guy's Avatar
Default Re: (89pre2.0si)
fix yours....the used replacement and the aftermarket new one will have the same crappy solder thats on your original. Put yours under a magnifying glass and check for cracked solder points on the circuit board. If your not comfortable soldering it yourself, and you have a reputable honda shop...have them solder it for you. should be about 30 bucks or so...
Old Jun 16, 2008 | 09:32 AM
89pre2.0si's Avatar
Default Re: (4WSi_guy)
aaaaahhh haha ok that's what i was trying to avoid because i cant solder. i already pulled it apart and cleaned some **** off of it and put it back in so it worked for a while and now it wont work at all. also after i put it back in, i lost all guages except spedometer, the only warning light coming on now is the batt light, and it still wasnt working very well. if i do manage to get it soldered will it possibly fix all of that?
Old Jun 16, 2008 | 06:17 PM
Buy a de-soldering tool and remove all the solder from under the circuit board. Then re-solder everything....
That's how I fixed my main/fuel relay and countless others.
88_hatch_ls
May 9, 2011 08:36 AM
Yuyodrift91
Jul 16, 2009 06:05 AM
vargas
Sep 3, 2008 04:27 PM
crx-king
21
Sep 19, 2007 05:35 PM
navin
15
Aug 1, 2004 09:14 AM
