Crankshaft damper
Hey everyone, a friend and i are replacing my timing belt and water pump on a b16 and dont have the recommened tool to hold the engine in place while your loosening the bolt on the crankshaft damper. Anyone have any suggestions or do need to get that special honda tool?
Thanks!!!!!!
Modified by STiM at 12:36 PM 6/8/2008
Thanks!!!!!!
you should get one of those tools just so you wouldn't be in this situation that you are in now.. an impact gun works... also if your flywheel is still on get something to stick into it against the block that keeps the crankshaft from spinning .. then get like a big bar.. ex: ( hollow bar off the giant floor jack etc .. and use that to break it loose..
cal_gecko
Apr 23, 2006 08:02 AM
serious
13
Sep 23, 2002 06:57 PM
