a/c question
Old Jun 8, 2008 | 10:40 AM
GYChris's Avatar
Default a/c question
I have a 92 Honda Civic dx hatch with a z6 swap.
the when i did the swap i let all r134 out. I left the a/c system open for a couple of months, which i know was a mistake but i got it closed up and nice and sealed with no leaks. Now that its summer, I got it evacuated and recharged. It blows ice cold now and feels great. Theres just one problem, when i turn the a/c on and the compressor kicks on.. .the motor bogs down and wants to stall. To temporarily fix the problem i just turned my idle up. So now my idle is up really high while not using the a/c, but when i turn it on its normal.
Could this be the IACV? or the compressor starting to lock up? any help would be appreciated
Old Jun 8, 2008 | 10:46 AM
count me out's Avatar
* B A N N E D *
Default Re: a/c question (GYChris)
your compressor is starting to bind up and putting a big load on the motor. if you continue to run it, it will shred internally and fill the lines with shavings, which will ruin your entire a/c system. replace the compressor asap.
Old Jun 8, 2008 | 11:01 AM
GYChris's Avatar
Default Re: a/c question (count me out)
yeah that makes sense. thanks for the input
can anyone verify this?
Old Jun 8, 2008 | 12:08 PM
Frozen E's Avatar
H-T White Ops
Did you add oil when you recharged it? Compressors need oil. Being open for a couple of months you should have dumped out all the old oil since it would have been saturated with moisture (refrigerant oil is very hygroscopic and sucks moisture up like no tomorrow).
psmoss
18
May 18, 2016 03:27 PM
b20bFourDoorCivicLX
Nov 30, 2013 08:56 AM
b20bFourDoorCivicLX
Oct 10, 2013 02:46 PM
NAxSOLDIER
Jun 10, 2011 08:06 PM
Tunerguy1989
Jun 24, 2010 04:47 PM
