could you guys please help me out
Old Jun 7, 2008 | 06:19 PM
teggy25's Avatar
Default could you guys please help me out
Hey guys, well i just recently bought this integra with just about 200k mile engine. And i was wondering was is the best tune-up/maintenance for my car.
I also need help on greasing my sunroof??
any ideas, thanks in advance
Old Jun 7, 2008 | 06:23 PM
jpeso23's Avatar
Default Re: could you guys please help me out (teggy25)
plugs wires, distrubtor, timing belt, water pump, oil change, trany fluid change, honda tranny fluid recomended..compression test....
put some vasaline, on the track, and run it back an fourth a couple times, or maybe some lithuim grease, but dont soak it........
Old Jun 7, 2008 | 06:42 PM
teggy25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpeso23 &raquo;</TD></TR><TR><TD CLASS="quote">plugs wires, distrubtor, timing belt, water pump, oil change, trany fluid change, honda tranny fluid recomended..compression test....
put some vasaline, on the track, and run it back an fourth a couple times, or maybe some lithuim grease, but dont soak it........</TD></TR></TABLE>
thanks alot man..
Old Jun 7, 2008 | 08:36 PM
Racermech's Avatar
if you dont know the history of the car do everything that is above, also I would add to that fuel filter and a coolant drain and flush.
Old Jun 8, 2008 | 11:16 AM
Myroslav69's Avatar
Default Re: could you guys please help me out (Racermech)
I absolutely agree with all of the above statements.
Old Jun 8, 2008 | 11:23 AM
90_EX_Civic's Avatar
Default Re: could you guys please help me out (Myroslav69)
all the above, and bleed your brakes, bleed your clutch(you never know), check your brake pads, check your brake calipers, and the guides for the brake calipers.
glenmore
Acura TL, RL & ZDX
May 25, 2012 11:18 AM
Corruption
Oct 6, 2006 08:24 AM
Rs xtreme 415
Nov 30, 2003 07:03 PM
who00knows
Jul 31, 2003 05:39 AM
IntEGNYC
Dec 5, 2002 09:16 AM
