Just got GSR running. now car shudders like motor mounts are lose at steady speed. HELP
Old Jun 7, 2008 | 03:56 PM
MPF_supra's Avatar
Default Just got GSR running. now car shudders like motor mounts are lose at steady speed. HELP
I threw a stock GSR motor back in my car, basic mods,
aem cold air intake
skunk 2 ecu
exhaust
8lbs flywheel
cm clutch
the car idles fine, drives fine, and this has nothing to do with suspension. i can't figure out what is causing my car to do such a violet shake. It happens at low RPM. Almost when your starting out at a red light and your starting to give it gas and bring up the RPM slowly the car freakin shakes like motor mounts are lose and the motor wants to fly back and hit the fire wall. I've check each motor mount and they are tight. This problem happens in every gear at low RPM and when your keeping the car at a steady speed ( say cruising in town and doing the speed limit like 30mph), Anything giving gas the car runs fine, car runs fine at higher rpm but if your not hammering on the gas it shakes. you can't keep the car at a steady speed at all or esle the car shakes (vehicle can be at any gear 3rd. 4th while cruising). When i'm on the highway it's fine, i can keep it 70mph and the car won't shake at all. Just don't know what the deal is. Anyone have any idea who ran into this problem?
thanks
Modified by MPF_supra at 1:17 AM 6/8/2008
Modified by MPF_supra at 1:20 AM 6/8/2008
Old Jun 7, 2008 | 11:26 PM
VRD^don's Avatar
Default Re: Just got GSR running. now car shudders like motor mounts are lose at steady speed. HELP (MPF_sup
check your axle's guy!!
Old Jun 8, 2008 | 05:36 AM
MPF_supra's Avatar
has nothing to do with axles. trust me
Old Jun 8, 2008 | 08:37 AM
Oreo-TeCk's Avatar
Default Re: (MPF_supra)
it may be the half shaft... it doesnt hurt to go over and check everything again....
Old Jun 8, 2008 | 11:31 AM
Myroslav69's Avatar
Did you check the torque mounts? I would go over everything, check each part one by one. How does your engine run at idle?
Old Jun 8, 2008 | 11:55 AM
MPF_supra's Avatar
like i stated, the car idles fine. 900rpm-1000rpm.
i have already triple checked the half shafts. threw new ones on than threw old ones that were good before i changed motor, still the same issue.
Old Jun 8, 2008 | 01:28 PM
VRD^don's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MPF_supra &raquo;</TD></TR><TR><TD CLASS="quote">has nothing to do with axles. trust me</TD></TR></TABLE>
trust me try it..same thing happened to sam's integra after tranny swap.
Old Jun 9, 2008 | 08:14 AM
MPF_supra's Avatar
don it's not the axles
bluskye
Sep 17, 2005 03:08 PM
iH8RICERZ
Feb 4, 2004 05:21 AM
9d9 EBP b16a2
Jul 5, 2002 01:50 PM
is3oo
Jun 4, 2002 12:08 PM
Gen5lude
May 16, 2002 11:28 AM
