how to fix code 13(atmosphere pressure)?
Old Jul 16, 2002 | 08:01 PM
EGHatchy's Avatar
Default how to fix code 13(atmosphere pressure)?
can anybody tell me how to fix this? and will this cause my car not to start? because its not...
Old Jul 16, 2002 | 08:08 PM
BreakStuff's Avatar
New User
Default Re: how to fix code 13(atmosphere pressure)? (EGHatchy)
Your car will start with a faulty baro sensor, thats just an evaporative emissions sensor to determine fuel tank pressure.. are you reading the code correctly??
Old Jul 16, 2002 | 08:57 PM
EGHatchy's Avatar
Default Re: how to fix code 13(atmosphere pressure)? (BreakStuff)
yea, I checked the code on 2 ECU's, both 13
Old Jul 16, 2002 | 09:09 PM
DR. ON POINT's Avatar
Banned
I believe that is the little black canister located right next to the battery. Let me guess, did u put a B series in a 96 civic CX or DX?
Old Jul 16, 2002 | 09:26 PM
EGHatchy's Avatar
Default Re: how to fix code 13(atmosphere pressure)? (On Point EK!!!!!!!!)
its a 92 B18A in a 91 Crx SI
Old Jul 17, 2002 | 02:42 AM
kinesistech's Avatar
The barrow sensor is usually under the dash on the passenger side. It is used to atmosphereic air density so the ecu can better understand the load values given by the MAP. The car would start if that was the only fault.
Old Jul 17, 2002 | 03:10 AM
EE_Chris's Avatar
Default Re: how to fix code 13(atmosphere pressure)? (kinesistech)
On later [96-99 at least] models, the BARO sensor is located IN the ecu.
Old Jul 17, 2002 | 05:17 AM
Banned
Default Re: how to fix code 13(atmosphere pressure)? (EE_Chris)
damn, I was so wrong, I am thinking of something else....
Old Jul 17, 2002 | 05:54 AM
brcivic411's Avatar
u are correct sir... and there's nothing that should stop your car from starting. I've had this code as long as i've had my turbo on.
DA_zooooms
Aug 10, 2009 09:08 PM
latinracerct
Oct 23, 2006 10:33 PM
$racer1
Mar 17, 2006 04:08 PM
ek9child
Feb 18, 2006 09:39 PM
THE FUCATYPR HATCH
Jan 27, 2005 09:17 PM
