What will happen if your primary o2 sensor doesnt work?
Old Jun 7, 2008 | 03:06 PM
raidacaipo's Avatar
Default What will happen if your primary o2 sensor doesnt work?
I know you will get a cel 41 but what else? primary controls air/fuel mixture ratios right? you will be running rich but what air/fuel mixture will your ecu give you in order to accomedate the non working o2 sensor? what will happen in the long run if u continue driving like this?
Old Jun 7, 2008 | 03:14 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: What will happen if your primary o2 sensor doesnt work? (raidacaipo)
Yes it will run rich, the ECU will run a default "safe mode" a/f ratio, mpg will suffer and catalyst damage can eventually occur. Not to mention you will fail smog since you're in CARBifornia.
Old Jun 7, 2008 | 03:18 PM
raidacaipo's Avatar
Default Re: What will happen if your primary o2 sensor doesnt work? (mcvtec)
do you know what the default a/f ratio it will be running?
Old Jun 7, 2008 | 04:24 PM
elektronsi's Avatar
not sure what default A/F ratio is but i imagine close to 14.7 (14.7 is optimal ratio) i know hondas run slightly rich, but no more than a few tenths difference, correct me if im wrong?
KCoupe
Apr 27, 2005 11:59 AM
d_mina
11
Dec 2, 2004 02:01 PM
AllMotorDA9
Oct 26, 2004 06:27 AM
NuclearB18B
Nov 7, 2003 09:33 PM
civicracer1993
Aug 27, 2002 06:50 PM
