HELP!! i cant figure out how to take this trim off
Old Jun 7, 2008 | 02:59 PM
89CRXProject's Avatar
Default HELP!! i cant figure out how to take this trim off
ok, so im preping my car, and the trim right here
(sorry pic is from a camera phone)
i found this nut, but that only takes off part of it. i took of the door panel on the inside to look for another nut, but there is a big bar where it should be, HELP!! what do i do?
Old Jun 7, 2008 | 03:44 PM
ugh..anyone?
Old Jun 7, 2008 | 03:52 PM
(EF)Edgar's Avatar
I took mine off with a screw driver,sure I bent them but I didnt care cause Im getting the JDM thin side moulding's.
Old Jun 7, 2008 | 04:00 PM
hmmm...maybe i have to sacrafice some clips behind the little bar in the door, i really need to figure this out, everything has been sanded down but the doors now....
Old Jun 7, 2008 | 04:43 PM
bobjohnson's Avatar
Default Re: (89CRXProject)
Take that bolt off. Work from the back side of the door. There are clips, you need 2 screw drivers to take them out, one on the top and one on the bottom. Or, go buy a panel puller tool, it makes it infinitely easier. Especially if you dont care about scratching the paint.
Search if you dont understand what im talking about. There was a thread about this less than a month ago where i gave detailed instructions on how to remove them. I dont really feel like typing 3 paragraphs again, especially when this stuff is in the service manual.
Old Jun 7, 2008 | 05:53 PM
hmmmmmmm awesome thanks for the help, i think i know what i gotta do
Old Jun 7, 2008 | 07:22 PM
hah, i got em, god that was a bitch
Old Jun 7, 2008 | 08:10 PM
welfarepc's Avatar
well what the hell did you do!? lol
i just left mine on and painted em
Old Jun 8, 2008 | 02:49 AM
Default Re: (welfarepc)
i didnt worry about scratchin the paint, so what i did was grabbed 2 flathead screwdrivers, they were small, probably #4 or #5
then what i did was took off that nut, there are 3 clips on there, i found the first one, its about in the middle, i wedged 1 screwdriver on the top and the other on the bottom, pushed the clips in, and at the same time i pulled the trim out, it was pretty hard, just like most jobs on these cars, it would be better if i had 3 arms.
then there is 1 about 3/4 down on the door, almost by the mirror kinda, then there is the last one,
i broke 1 of the clips, but its alright, i guess i shoulda just ripped em all off, cause i gotta go buy new clips anyways, but i tried not having to buy some new ones.
Old Jun 8, 2008 | 03:22 PM
crxcess's Avatar
you can get most of them from the inside of the door with a pair of pliers. takes a while to get the angle right, but its not too bad.
Old Jun 8, 2008 | 06:30 PM
welfarepc's Avatar
cool. glad you got em off.
i had to break the clips for the window trim, but there was no way in hell i was leaving them on.
good luck on your project!
Old Jun 8, 2008 | 11:22 PM
24TEN's Avatar
PHANTOM MENACE
FYI-Seems no one knows this technique. I did this on my hatch, I'm sure it's the same on the CRX too. Those clips slide into the door molding in one direction only. The correct way is with the specific tool to pinch the clips and remove each one. The usual trick is to remove them with two flat heads. Here's the way I found. Remove that one nut on the inside of the door and use a mallet to tap the door molding forward. Since the clips only go in one direction on the molding, it will slide off, leaving the clips on the door and seperating the molding from the clips. Once it's off, you can twist each clip and remove them one by one from the door and reinsert them onto the molding. Then when you are ready, just press the molding back into place and you're done.
Old Jun 9, 2008 | 04:42 AM
bobjohnson's Avatar
Default Re: (24TEN)
That only works if no ones flipped over one of the clip seats. And if any of the clips are broken, good luck getting them out of the door.
Old Jun 9, 2008 | 10:41 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: (bobjohnson)
actually I retract my previous statement. i believe bobjohnson is correct. i forgot that the seat itself is a seperate piece that can be installed in either direction. you can try my method at your own risk.
Old Jun 9, 2008 | 06:41 PM
Default Re: (crxcess)
crxess, i couldnt do that, i have the 90-91 doors, they have the support bar for safety
i agree with you 24ten and bobjohnson also, after i got both peices off i noticed that also
Old Jun 10, 2008 | 10:16 AM
crxcess's Avatar
so did mine, you can still access them.
slo2k
Honda S2000
12
Apr 19, 2010 07:29 PM
Teg LS
Aug 7, 2008 08:36 PM
EJcivicJDM7
Mar 8, 2008 03:14 PM
killaj12
11
May 6, 2007 02:38 PM
VietFoo
Mar 9, 2004 09:43 AM
