wiring harness Q for my DFI...
Old Jul 16, 2002 | 07:53 PM
DA666's Avatar
Default wiring harness Q for my DFI...
okay..i have a 92 integra ls b18a1, i just got my standalone, DFI..wooooohooooo!
and i have a cx wiring harness(engine bay), obvioulsy obd1, and non vtec...same as my b series ls wiring harness, obd1 non vtec.
my q is:
are these two wiring harnesses exactly the same, because with DFI, you wire in the sensors and replace the stock, i want to know for sure before i wire in the sensors to the cx harness to save downtime. i know these sensors clip
right in as it is the same...but are tthere any tech differencees?
and is any one familar with DFi installs?
tthanks alot for the replies guys.
Old Jul 17, 2002 | 02:50 AM
kinesistech's Avatar
Default Re: wiring harness Q for my DFI... (T3T4DA6)
Both harnesses are pretty much the same. I think that teh radiator fan switch is on the thermostat housing on a cx and the b18a has it near the oil filter on the back of the block. You DFI shouldnt care but you should. I have no experience to lend of DFI so good luck.
92 teggy
Feb 24, 2010 05:35 PM
b18c5eg
Dec 23, 2002 02:22 PM
