OBD0 and OBD1 chips???
Old Jun 7, 2008 | 11:06 AM
AK94GSR's Avatar
Default OBD0 and OBD1 chips???
can these chips be swapped from one ecu to the next
my friend has an obd 0 chipped ecu. he now has an obd1 ecu with jumper harness and would like to you that instead.
is this possible??
Old Jun 7, 2008 | 11:48 AM
GhostAccord's Avatar
Default Re: OBD0 and OBD1 chips??? (AK94GSR)
No an OBD0 chip will not work in an OBD1 ECU. They do not use the same code base. Your buddy will need to find someone that can read the OBD0 ROM (turbo edit) information. Then use that info make a new base using OBD1 ROM editor (Crome, uber, eCtune). Then they can take the same chip and burn the OBD1 code base onto it.
Modified by GhostAccord at 10:10 AM 6/8/2008
Old Jun 7, 2008 | 12:59 PM
AK94GSR's Avatar
Default Re: OBD0 and OBD1 chips??? (GhostAccord)
k thanks for the quick reply
ricardo13d
11
Dec 8, 2011 06:55 PM
G2integra217
May 8, 2005 11:39 PM
Maddox
Apr 5, 2004 07:03 PM
ViperRedCRX
May 19, 2003 01:01 PM
