Disc brake conversion question
Old Jun 7, 2008 | 10:14 AM
shaggyeg6si's Avatar
Default Disc brake conversion question
Okay, so I have a set of DC rear disc brakes, complete with trailing arms. I was told that in order for these to fit, I would have to change the main trailing arm bushings to DA type. I might as well just go with ES and do it, but my question is, can I just bypass this altogether and just change the hubs. Leave the trailing arms?
Old Jun 7, 2008 | 11:08 AM
CRX Toad's Avatar
Default Re: Disc brake conversion question (shaggyeg6si)
I WOULD NOT DO ES TRAILING ARM BUSHINGS. You need to do your re<FONT COLOR="red">search</FONT> on this.
You can change the hub it can be a little bit of a P.I.T.A.
https://honda-tech.com/zerothread/1508680
http://fourthgenhatch.net/howto.html
Old Jun 7, 2008 | 11:32 AM
Default Re: Disc brake conversion question (CRX Toad)
Why no on the ES?
sk8board{Pete}
Oct 22, 2008 09:17 AM
DailyBlown
Jul 8, 2004 10:42 AM
MugenHonda
Jun 12, 2003 05:14 PM
JDMACCORD
Feb 12, 2002 09:11 PM
