Installing Air Conditioning (A/C) on an EG
Old Jun 7, 2008 | 10:08 AM
Morasso's Avatar
Default Installing Air Conditioning (A/C) on an EG
So i'm planning on installing A/C into my car. Its a 1993 Civic CX. I've heard mixed things on installing it. I've heard its a bolt on procedure, and from other people i've heard its really hard to do.
Heres the kit I was going to buy
Its from a local guy, 75 bucks for everything All lines, condensor, compressor, fan, wiring harness for under the hood and dash, and the black box thing that goes under dash.
I know that i'll also need the belt and bolts for everything, but does anyone happen to have a write up or some advice for doing this?
Side note: I'm on trial status because I hated on a mod, so until I get off it i'm not able to answer PMs. So try to post all your info in here if you would.
Thanks guys
Old Jun 7, 2008 | 10:12 AM
BlueIntegraBoy's Avatar
Default Re: Installing Air Conditioning (A/C) on an EG (Morasso)
http://www.hondaautomotivepart....html
Old Jun 7, 2008 | 10:16 AM
instructor74's Avatar
Default Re: Installing Air Conditioning (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondaautomotivepart....html</TD></TR></TABLE>
Thats the one you need. before you start make sure and replace all the oring seals on the ac lines. You will also need to replace the ac dryer its the foot long small cylinder in the photo has a little glass eye on top once that is open to the air it should be replaced. Its not a hard job just take your time. on other thing you will neeed if you don't have it is the button cover for the climet control inside the car. there is a dummy plate covering the lable and the button just remove it and snap the cover in place
xXViperXx
Feb 13, 2010 05:40 PM
brewski
Oct 26, 2009 06:12 PM
oojaybeezyoo
Jun 6, 2007 05:57 PM
bambbrose
Oct 31, 2005 11:59 PM
eL
35
Jul 29, 2004 01:13 PM
