!!!WHERE DO I CUT!!!! FOG LIGHTS
I have a 99ek coupe.. I just installed a clifford 770. And now I'm slapping all the stuff I have in my garage on. I need help with the fog lights cuz I don't kno the perfect spot to cut. I searched and stuff but all I can find is the drawing diagram.. Can anyone help me plzz. Got any pics or something??? Thanks
i recently did fogs on my EM1 and the supposed marks on the back werent there, so what i did was take the housing and from the back of the bumper trace and cut out the hole inside the housing where the fog light itself goes, then test fit, ofcourse the first or second time you cut it will not fit, but after each time you cut out a little more material and after a few tries it should be nearly perfect,
P.S. the housing is fairly bigger than what needs to be cut out so even if you cut a little too big you shouldnt have a problem, but absolutely make sure you cut a little bit at a time, test fit, cut more, and repeat the process
sorry no pics, digi is broke
http://handaccessories.com/civ...s.pdf
its not that hard to just start cutting. i cut out my first whole b4 i realized there werre dots there. just dont cut out 2 much at once and ur good. gonna take a couple test fits to get it but its nothin hard.
i did mine freestyle on a freshly painted bumper, its not that hard, like it said, take the bumper off, put the housing on the backside of the bumper, mark for the fog light, and cut it out, then test fit(it wont fit the first time) and cut a little more each time until it fits properly, as long as you take your time and dont rush you will be fine
