Integra SEDAN spoiler removal
Is this any different for a 98 sedan vs a 2dr? To my understanding, all I have to do is unscrew the 2 bolts under the trunk, lift the spoiler off the trunk, and the wires and their plugs will just show themselves? Then I can unplug and tuck the plugs back into the trunk lid? (I believe the spoiler on the car is a OEM with brakelight) Thanks!
Also, when I go to home depot, where can I find those plugs? What are they called? Pictures of integras with plugs would be greatly appreciated.
Two acorn nuts on both sides of the trunk. Just unbolt them. Then use fishing line on the adhesive gasket to remove the spoiler from the trunk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Two acorn nuts on both sides of the trunk. Just unbolt them. Then use fishing line on the adhesive gasket to remove the spoiler from the trunk.</TD></TR></TABLE>
Yes.. should be 4 (10) mm nuts.. Then unplug the harness to the spoilers brake light and plug it into the connector on the rear hatch glass.. if you do have 3rd brake light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silversedan »</TD></TR><TR><TD CLASS="quote">Will it leave a sticky residue? Also, I assume I can easily install it back on as easy it was to remove?</TD></TR></TABLE>
It might leave a sticky residue, but i'll come off with some scrubbing and yea you can install it back easily
I seem to be stuck on this seemingly simple task. I removed the screws and the 1 wire going from the trunk lid to the spoiler is on the passenger side of the trunk. I go to pull it out of the trunk, and it is suck and I see to wire clip. I also cannot pull it from out of the spoiler. What am I missing? Do I have to cut the wires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silversedan »</TD></TR><TR><TD CLASS="quote">I seem to be stuck on this seemingly simple task. I removed the screws and the 1 wire going from the trunk lid to the spoiler is on the passenger side of the trunk. I go to pull it out of the trunk, and it is suck and I see to wire clip. I also cannot pull it from out of the spoiler. What am I missing? Do I have to cut the wires?</TD></TR></TABLE>
I had to cut mine and use small butt connectors..
To cover the holes up, you can use E-tape and cut a couple small circles out of them (bout the size of of a penny). Afterwards, use matching touchup paint and paint the circle E-tape cutouts and slap em on. Smooth as butter if you do it right. I wish I had a better pic of my old DB to show you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">To cover the holes up, you can use E-tape and cut a couple small circles out of them (bout the size of of a penny). Afterwards, use matching touchup paint and paint the circle E-tape cutouts and slap em on. Smooth as butter if you do it right. I wish I had a better pic of my old DB to show you.
Love the DB..Especially the pic with the Cop in the background. Where do you get E-tape? how does it look like?
</TD></TR></TABLE>Love the DB..Especially the pic with the Cop in the background. Where do you get E-tape? how does it look like?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drint3gr4 »</TD></TR><TR><TD CLASS="quote">
Love the DB..Especially the pic with the Cop in the background. Where do you get E-tape? how does it look like?</TD></TR></TABLE>
E-tape = Electrical tape
