Car dieing after reaching operation temp
I'm a NOBIE here but not to the cars
I have a problem with 98 CIVIC LX
when it reached operation temp it shoots off , just like that
recently replaced parts due this issue
-timing belt
-water pump
-crank shaft position sensor
-valve adjustment
-new battery
-spark plugs +wires
-new distributor
it feels like fuel is cutted of by ECU but what do I know
NO CEL
PLEASE HELP
post any idea
thanks
-timing belt
-water pump
-valve adjustment
-new battery
-spark plugs +wires
-new distributor
NO CEL
PLEASE HELP
post any idea
thanks
i had this same problem with my d16z6 what i went to first was my engine temp sensors these engines have two replace them or just plain ground them out to see if that is what your problem is. If not im sure you have a buddy that has the same ecu stick theirs in there and take a few pulls.... also check ALL ground wires for corrosion and/or fraying. let me know if this helps.
please help
my friend told me this
" bought my old tempo beater for $500 with a blown HG. i could drive around for 15 mins or so, and once up to temp(thermostat opened)...it just died. large enough gulp of anti-freeze and it stalled.
it would take AT LEAST 24 hours before it would restart. trying to restart it before that time would not increase the time...in other words, the clock wouldn't restart.
the issue started with bucking and hesitation...when the previous owner(a friend) had the the car diagnosed(by another friend). once the gasket got bad enough...it mimicked pawels civic.
thoughts?"
thoughts?"
forevermemorabl
27
Sep 20, 2013 07:43 PM
95civhb
13
Feb 15, 2011 12:34 PM
