Info on sir 1 b16
Old Jul 16, 2002 | 07:28 PM
td04civic's Avatar
Default Info on sir 1 b16
i wanted to know if anyone knows any good sites about installing a sir 1 b16 motor in a crx.
Thanks
Old Jul 16, 2002 | 07:34 PM
Griffins_Importuning's Avatar
Default Re: Info on sir 1 b16 (td04civic)
http://www.hasport.com has every thing u need to know....
Old Jul 16, 2002 | 07:38 PM
EF_LSVtec's Avatar
Default Re: Info on sir 1 b16 (Griffins_Importuning)
Here's another site... http://tech.hybridgarage.com/tech/index.html
Old Jul 16, 2002 | 07:44 PM
Default Re: Info on sir 1 b16 (EF_LSVtec)
basically here is what u need models are a lil different. mine was a hf so i needed
engine mounts(place racing or hasport)
shift linkage
integra lower and upper rad hoses
teg throttle cable
hubs and nuckels from non hf crx or civic non ex
teg axels
(should do new timing belt and water pump, new spark plugs and wires)
i also needed new o rings for injectors(if they are green get new ones)
check the rotor and cap when u get the engine(i had to replace them)
wiring harness(the si and hf can use sub harnesses $75 from hasport.com)
use the harnes from your crx
the rest is basically just plug and play
oh yea..also u will need to pound out your crossmember a little to get your exhaust manifold to fit....also pound in your driver side fender well a little where the alternator belt is....i forgot to do this and i have not even a 1/2 inch clearance....
Old Jul 16, 2002 | 07:46 PM
make sure u do some researching before your install the engine. make sure you have everyting and the swap will go quicker and eaisier....i woould also suggest replaceing the clutch. i wish i would have now. i swapped the b16 in about 3 weeks ago and clutch is stating to gring a little.....its up to u
stegs
Mar 21, 2008 09:59 AM
xtokex
Sep 22, 2007 04:15 AM
crxtasy_12
Apr 4, 2003 08:26 PM
lordhuh
Jul 24, 2002 08:01 AM
Cory man
Dec 9, 2001 02:02 PM
