weird thing i saw at work....
yesterday at work.. there is a eg hatch.. with a zc bottom end... but it has a stock d series top end...
and it looks to be running a stock d-series trans... if so is this a popular swap? changing the motor in the car back to stock.. d-15b7 boss doesn't want zc bottom end.. s i was going to do that swap for myself.. sohc on zc bottom.. if it works
zc's are basically a single block, there is a zc DOHC head that will fit on it, (looks exactly like an LS swap) but yeah..
zc's come in both dohcs and sohcs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohsnapzafingcu »</TD></TR><TR><TD CLASS="quote">zc's are basically a single block, there is a zc DOHC head that will fit on it</TD></TR></TABLE>Nope, ZC is just what they call a few of the D-series in Japan. You can't swap a dohc head onto a single cam block. They're not the same block.
In fact, I'm pretty sure the only D-series that's not called a ZC in Japan is the D15B.
Modified by TrippinBull at 9:34 PM 6/8/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrippinBull »</TD></TR><TR><TD CLASS="quote">Nope, ZC is just what they call a few of the D-series in Japan. You can't swap a dohc head onto a single cam block. They're not the same block.
Modified by TrippinBull at 9:34 PM 6/8/2008</TD></TR></TABLE>
yeah, i was trying to say only the dohc zc head will fit on any zc block. i'm bad at explaining things
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT_TURN_U »</TD></TR><TR><TD CLASS="quote">SWEET.. so zc botton end it is.. but does anyone make cams for the dohc zc?</TD></TR></TABLE>
someone said they look like LS's but i don't know about that. take em out and compare!
yeah, i was trying to say only the dohc zc head will fit on any zc block. i'm bad at explaining things</TD></TR></TABLE>
except only dohc zc head fits on dohc zc block, and sohc on sohc. the dohc head doesnt fit on any d-series that wasnt dohc from factory
You have s SOHC ZC, so why wonder about cams for a DOHC? (confused)
i was going to run that sohc zc block and get a dohc zc head... but that doesn't work.. so i guess its back to porting the d15 head we have laying around the shop... and ending up with 11.5cr lol
