1993 Del Sol 1.6l SI - Starting issue
Old Jun 6, 2008 | 06:16 PM
TaSe's Avatar
Default 1993 Del Sol 1.6l SI - Starting issue
What's up all, its been a while since i've been here but i have a small concern.
I have a 93 del sol with 180k miles on it. I tried cranking it over but no go. I hear the starter spinning but it doesn't crank the motor. The person i purchased it off of said they just replaced the starter not too long ago.
Does anyone know what it could be? defective starter? distributor? alt? fuses? solenoid?
Old Jun 6, 2008 | 06:31 PM
CarTuner1984's Avatar
how's the battery? if the battery is good check all your ground and power connections, there is a possiblilty the the starter isn't engaging to the flywheel, but try the cheaper things first
Old Jun 6, 2008 | 06:34 PM
z6hatchboy's Avatar
Default Re: 1993 Del Sol 1.6l SI - Starting issue (TaSe)
If the starter is indeed spinning, somehow its not engauging power to the flywheel. Take the starter off and look at the flywheel, if its teeth are good then probably just a bad starter.
Old Jun 6, 2008 | 06:40 PM
TaSe's Avatar
will do thanks
new distributor and battery in car already
Old Jun 6, 2008 | 06:41 PM
Default Re: 1993 Del Sol 1.6l SI - Starting issue (z6hatchboy)
x's 2, I'm with him, i had a problem with my friends car and they did'nt have the starter in flush and it would engage but wouldn't come out and hit the flywheel. So check and see if it sets flush on the tranny.
Old Jun 10, 2008 | 10:25 AM
TaSe's Avatar
Default Re: 1993 Del Sol 1.6l SI - Starting issue (CarTuner1984)
bad starter problem solved, thanks guys
cbaber
Jan 6, 2010 05:15 AM
fwdftw
Aug 28, 2006 07:23 PM
S2KBAR
Feb 24, 2006 01:37 PM
funkfnamna
Apr 12, 2005 01:36 PM
