Redline on a K24
Old Jun 6, 2008 | 03:17 PM
EduardoDC5's Avatar
Default Redline on a K24
hhmm well im reading that the k24a2 redlines at 71000 when the type-s redlines at 83000 when you swap the block with the head can you only rev to 71000? or up to 83000? thanks i haven't seen this question around
Old Jun 7, 2008 | 05:28 AM
SSM_TypeS's Avatar
Default Re: Redline on a K24 (EduardoDC5)
if you put a k20 head on a k24 block you should be able to rev to 8200
Old Jun 9, 2008 | 10:53 PM
k24_dc5's Avatar
Some people take it to 8200+. Kpro stops at 7600 in the preloaded calibrations.
An occasional trip to 8000+ probable isnt too bad, but the pistons speeds are pretty high so damage is more likely.
Old Jun 10, 2008 | 10:05 AM
preludedriva's Avatar
Default Re: Redline on a K24 (k24_dc5)
isnt the k24 a longer stroke too? or is it just a bigger bore?
Old Jun 10, 2008 | 11:53 AM
k24_dc5's Avatar
Default Re: Redline on a K24 (preludedriva)
yes its a long stroke. 99mm. and they have a slightly larger bore.
Old Jun 10, 2008 | 08:04 PM
FerreiraCompetitions's Avatar
Reving that 99mm stroke to 8000rpms produces piston speeds of over 5000fpm... deep into the unreliable zone. As an example; its about the same pistons speeds you would get if you were to rev the K20 to 9200rpms.
Lightning the whole rotating assembly is the path to go before some ugly things happen.
Old Jun 24, 2008 | 07:09 PM
hondapunkrock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EduardoDC5 &raquo;</TD></TR><TR><TD CLASS="quote">hhmm well im reading that the k24a2 redlines at 71000 when the type-s redlines at 83000 when you swap the block with the head can you only rev to 71000? or up to 83000? thanks i haven't seen this question around</TD></TR></TABLE>
sure wish my car would rev to 71,000! image 83,000! would take a day to redline
Old Jun 24, 2008 | 07:33 PM
RedDC5's Avatar
Default Re: Redline on a K24 (hondapunkrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapunkrock &raquo;</TD></TR><TR><TD CLASS="quote">
sure wish my car would rev to 71,000! image 83,000! would take a day to redline </TD></TR></TABLE>
lol! Imagine vtec up there!
Old Jun 24, 2008 | 08:17 PM
simonEp3's Avatar
Default Re: Redline on a K24 (RedDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedDC5 &raquo;</TD></TR><TR><TD CLASS="quote">
lol! Imagine vtec up there! </TD></TR></TABLE>
That would be AWESOME. Hooray for the Vtak!!!
Old Jun 27, 2008 | 12:42 PM
JesSi's Avatar
You could go... to the moon.
SilverEk3dr
Apr 30, 2009 07:53 AM
ITRnorway
Nov 16, 2006 01:54 PM
type B16
Aug 20, 2006 11:41 AM
91DroppedHatch
Mar 8, 2005 10:13 PM
