Let the bashing begin....dyno with Hondata base JUN 3 maps on my car
Old Jul 16, 2002 | 06:53 PM
canuck-mx6's Avatar
Default Let the bashing begin....dyno with Hondata base JUN 3 maps on my car
Not to make excuses or anything, but it was 35 degrees today in Toronto. The shop is poorly ventilated, and it was hot with fumes in there.
Also, I am running so rich, that the shop is filled with black fumes by the end of the run . I have some major leaning out to do The cam gears were untouched as I just wanted to know what the car was making with the base maps. The redline is with the fuel partially tuned (just to ensure that I was not leaning out anywhere). My tuner is away, and this is the first chance to hit the dyno that I have had. Take a look at the temperature in the shop
By comparison, this is another Jun 3 dyno with the following mods:
Mods: DC Sports built B18C5, DC Sports JDM 4-1, DC Sports 2.5" TCS exhaust with S2000 Cat, DC Sports fuel rail, cam gears and DAC intake with Cold AIr Extension, JUN ECU, Type 2 cams, springs and flywheel, Crower rods, JE pistons, Portflow head, Benson's sleeved block, RC injectors, Ferrea .5mm O/S valves
Tuned V-AFC for proper fuel / air ratios.
Peak HP: 202.4
Peak TQ: 134.8
[Modified by canuck-mx6, 4:09 AM 7/17/2002]
Old Jul 16, 2002 | 07:00 PM
YelLowITR's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (canuck-mx6)
are you running straight pipe? if not, i recommand you to do that, my car with JUN3 put down 185, after straight, it goes straight up to 200 ! and stock ECU
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
I see lots of potential, good luck.
Old Jul 16, 2002 | 07:14 PM
baonest's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (Rguy)
good deal.. thats similar to my setup.. when are u going to get track times..??
Old Jul 16, 2002 | 07:15 PM
Malice's Avatar
New User
OUCH!!!!
Old Jul 16, 2002 | 07:48 PM
hybrider's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (C5_ALLMOTOR)
very very sweet
Old Jul 16, 2002 | 09:21 PM
dohcsideSi's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (hybrider93)
55-56 degrees on the 2nd dyno damn that's cold.....
Old Jul 16, 2002 | 09:22 PM
xtrafastcivic's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (dohcsideSi)
i think he means celcius damn canucks j/k
Old Jul 16, 2002 | 09:23 PM
SurferX's Avatar
Don't the SAE numbers correct for temp? I didn't think it mattered what the temp was with the SAE corrected numbers.
Old Jul 16, 2002 | 09:35 PM
ITR21's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (SurferX)
good luck with the tunning wayne.
Old Jul 16, 2002 | 11:10 PM
Tommy_Gunns's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (XtraFastCRX)
Yeah...celcius, not ferenheit...fricking americans
Old Jul 16, 2002 | 11:11 PM
Looks good Wayne, can't wait to see how she runs tuned.
How many KM's did you put on the motor before these runs?
Old Jul 17, 2002 | 12:52 AM
MackSpeed-616's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (Tommy_Gunns)
here is a REAL jun 3 map for comparison
MODS:
CTR Pistons
Jun 3 Cams
SMSP header
Hondata
STOCK Intake
STOCK Head
STOCK Exhaust
Old Jul 17, 2002 | 01:02 AM
00MRSi's Avatar
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (BustaNutt-616)
With more tuning your #s will go up..
Wow.. BustaNutt, nice #s with stock I/E. There's gotta be more power available with an AEM or Icebox and nice free flow (SMSP) exhaust..
Old Jul 17, 2002 | 01:37 AM
Default Re: Let the bashing begin....dyno with Hondata base JUN 3 maps on my car (00MRSi)
is it just me or is that second graph pretty weak?
202whp with all that work???
i dont have half the mods he has and and my motor makes almost to whp
and it was only 50 degress! i dyno'd at 70degrees.
Old Jul 17, 2002 | 04:49 AM
canuck-mx6's Avatar
The corrected numbers reflect how much the temperature readings will affect the dyno. There is no way that it can factor in how the heat afftects the car, as each car will be different.
I drove an hour to the dyno and proceeded to dyno with almost no cool down period. After the second run, the only cool down was the time that it took me to swap the chip in the ECU.
High compression motors run really hot, and they are really susceptible to heat soak, mine is no exception. With a temperature inside the shop of 93.7 F, and even hotter outside, I am losing a bunch of power there.
The way the car runs when it is cool is night/day to the way that it runs when hot. Also, these are just the base maps from Hondata, neither fuel or timing has been adjusted for my car. I will post another dyno when all of this gets tuned properly
Old Jul 17, 2002 | 05:15 AM
RTW DC2R's Avatar
well for comparison...my car put down 178 with just AEM and Mugen USDM headers...stock everything else. I think you should be able to get a lot more from that set up. keep workin on it.
Old Jul 17, 2002 | 05:22 AM
JPP's Avatar
JPP
Humm... 55 Celcius = 131 Farenheit = maybe in Death Valley but not in Toronto
55 Farenheit = 12 Celcius= canadian temp. in spring or fall (frisky but we canucks are not wussies)
[Modified by JPP, 9:22 AM 7/17/2002]
Old Jul 17, 2002 | 05:25 AM
DX Generation's Avatar
Don't be discouraged my friend, I'm sure with some more tuning, you should see your #'s go up.
Good luck.
jv88_dc2
Sep 4, 2010 01:00 PM
TypeR-R6
Aug 17, 2002 10:18 PM
