Electric Oil Pressure Gauge Install !!!!!!!!
Whats going on members, I know this has prob been covered over and over agian, but i cannot find anything, is there a write up on H-T here for installing an electric oil pressure gauge, like the part numbers for the brass T connectors and everything I need to install and hook this gauge up, any help would be greatly appreciated.
Thanks
Thanks
the guage should have come with a sender thats abut the size of shift ***
it should fit right up
you can use your stock pressure sender place since the stock is worthless
the light only turns on when your only getting about 15 lbs of pressure to the engine and by that time your causing damage
the sender should be to the left of your oil filter
make sure your engine is cool and take it off
then put the after market sender on
now since its electric there should be three bolts on the back like so
_ _
_
top left is psitive to a power source
top right is for the sender
and bottom is for the ground
you can hook up the ligt to the bolts too so you dont have to [freak] with all the extra wires lol
have fun its really simple once you start doing it
hope this helps
ps: the bolts should say (+) (-) (sender)
im just going off mine from autometer
_ _
_
hope this helps
i had the same question a while back heres the thread i posted on azht
http://www.azht.net/forum/show...ssure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_B18b1_Teg »</TD></TR><TR><TD CLASS="quote">i had the same question a while back heres the thread i posted on azht
http://www.azht.net/forum/show...ssure</TD></TR></TABLE>
Thank you
Thank you
Petah
Apr 24, 2002 12:31 PM
94, acura, electric, electrical, gauge, guage, honda, install, installation, installing, instructions, integra, oil, pressure, sender
