MTX Dual 12" Sledgehammer Enclosure and Thunder Elite 1600watt Amp
MTX sledgehammer 7500 series:
RMS Power : 800W
Max Power : 1600W
Impedance : 2Ohm
Frequency response : 38Hz - 150Hz
Sensitivity : 96.3 dB/1W/1m
Woofer diameter : 2x30cm (12’’)
Xmax : 17mm
Dimensions (HxWxD) : 36,2x87x45,7cm
High output MTX Sledgehammer Enclosure
Vented enclosure with T7500 superwoofers
2 ohm impedance, optimised for use with a class-d amplifier
Carbon filled expanded polypropylene cone with aluminium deposit
Butyl rubber surround
Stitched cone to surround
Spider Plateau Venting (SPV)
Asymmetrical Linear Drive System (ALDS)
Congruent Edge Technology (CET)
Unique slot port design
designed to deliver loud and accurate bass
Internal wiring from Streetwires
Thunder Elite 801D Specifications:
# OF CHANNELS 1
CLASS D
POWER SUPPLY Semi Unregulated MOSFET
(Pat. No: US05598325) x
THD + NOISE (1 Watt) ≤.5%
FREQUENCY RESPONSE (-3dB) 20Hz-200Hz
SIGNAL-TO-NOISE RATIO (1 Watt) 70 dB
OVERLOAD PROTECTION
THERMAL PROTECTION
14.4VDC POWER 4 Ω 400w rms
2 Ω 800w rms
Peak Power 1600w
BI-LEVEL INPUT (RCA Connection) Low Level
Hi Level w/ Smart Engage (Pat. No: US06556683)
INPUT SWITCH Input Sense 100mV-1V/1V-10V
GAIN CONTROL MONO - 100mV-10V
CROSSOVER LOW @ 40Hz - 200Hz, 24dB
SUBSONIC @ 30Hz, 12dB, Defeat
EQUALIZATION QUASI Parametric: Boost/Cut ± 12dB, Freq. 30Hz-80Hz
OTHER FEATURES Remote Subwoofer Level Control Parallelable
Prizm EFX With Demo Mode
POWER CONNECTION 4 Gauge Direct Input With 8 Gauge Direct Cap Input
DIMENSIONS Height 9-5/8"
Width 16-11/16"
Depth 2-1/2"
this is not a cheap setup by any means, and if it doesnt sell for the price i want, ill just keep it. im asking 500 firm *price drop. the amp alone retails for 579.99 on crutchfield.
http://www.crutchfield.com/S-a...E801D it will come with power and ground wire with fuse holder. im keeping the rca's and remote wire for the new system. here are pics with it in my integra. ive had it for about 6 months, but i just got my car running so its only had about a month of use.
Modified by patrick4588 at 3:31 PM 9/17/2008
RMS Power : 800W
Max Power : 1600W
Impedance : 2Ohm
Xmax : 17mm
# OF CHANNELS 1
CLASS D
OVERLOAD PROTECTION
THERMAL PROTECTION
2 Ω 800w rms
Peak Power 1600w
Width 16-11/16"
Depth 2-1/2"
From: New York in the summer, South Carolina in the winter
bump for the thunder elite amp
I used to have a TE2500 that i got when i worked at a stereo shop. stuffs NUTS
will separate the subs from the amp. 350 for each. the amp is now on ebay. http://cgi.ebay.com/ws/eBayISA...96814
