Just picked up a 94 accord with broken timing belt. what are the chances of bent valves
Old Jun 6, 2008 | 05:33 AM
28's Avatar
28
Default Just picked up a 94 accord with broken timing belt. what are the chances of bent valves
94 Accord auto, base model. 215k miles. The previous owner was going slow, probably 15 mph off a stop light when it broke. I have read that these are interference engines, but not always.
Old Jun 6, 2008 | 06:07 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Just picked up a 94 accord with broken timing belt. what are the chances of bent valves (28)
they are interference engines so chance of bending something are pretty good.
you could buy a new belt and throw it on, then do a compression or leakdown test and see how it checks. Or pull the head and inspect it.
Old Jun 6, 2008 | 06:13 AM
28's Avatar
28
Default Re: Just picked up a 94 accord with broken timing belt. what are the chances of bent valves (Tourin
I've read a few people on here saying that a lot of cars survive the belt break if it is at low RPMs and someone even said survival is higher on automatics (not sure why)
Its a $150 car I basically bought for scrap, but if its as simple as throwing a T belt on I might do it if my chances are 50/50
Old Jun 6, 2008 | 06:24 AM
H-T Order of Merit
i didn't say you would definitely have bent valve, just chance are pretty good since it is an interference engine.
would I say 50/50, maybe...
some people have said they've broken a timing belt and gotten lucky, but how trusting of the seller are to trust the statement of 15mph? They were leaving a stop light, were the rpms high? Manual in 1st gear could be high enough depending on how they were driving.
not sure about that statement about the auto's though, don't get why it would be different.
For the cost of a belt, I'd probably just get one, put it on there and see how it checks by doing a compression or leakdown test. I mean it can't hurt since you bought the car for only 150.
Old Jun 6, 2008 | 06:26 AM
28's Avatar
28
I trust the sellers statement of 15mph because I was driving in a parking lot when I saw the accord break down. He basically left a stop light and coasted into the parking lot when it died.
Old Jun 6, 2008 | 06:29 AM
H-T Order of Merit
gotcha
Old Jun 6, 2008 | 07:00 AM
28's Avatar
28
I'd like to hear from someone that has successfully not damaged valves... then I would probably throw a belt on
Old Jun 6, 2008 | 08:40 AM
H-T Order of Merit
in all honesty, not trying to be rude, just because someone comes into your thread and says they lucked out isn't going to change your chances. You said it yourself that you've read of people not damaging the valves, what more do you need? If you feel confident that it was low rpms and the person didn't just sit there and try cranking and cranking it to try starting it then why not try a new belt? I'm not saying to buy everything, just get the belt and see how it does first. If it's fine then go ahead and do all the other stuff like the seals, water pump, tensioners, ect. Yeah, you'll be doing the job twice but it's better than pulling the head to inspect or buying everything just to find out some valve are bent. This way you would only be out time and the money for the belt.
Modified by TouringAccord at 12:49 PM 6/6/2008
Old Jun 6, 2008 | 08:47 AM
28's Avatar
28
I'd like to get a few more replies.
Old Jun 6, 2008 | 09:03 AM
NeKe1point0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">in all honesty, not trying to be rude, just because someone comes into your thread and says they lucked out isn't going to change your chances. You said it yourself that you've read of people not damaging the valves, what more do you need? If you feel confident that it was low rpms and the person didn't just sit there and try cranking and cranking it to try starting it then why not try a new belt? I'm not saying to buy everything, just get the belt and see how it does first. If it's fine then go ahead and do all the other stuff like the seals, water pump, tensioners, ect. Yeah, you'll be doing the job twice but it's better than pulling the head to inspect or buying everything just to find out some valve are bent. This way you would only be out time and the money for the belt.
Modified by TouringAccord at 12:49 PM 6/6/2008</TD></TR></TABLE>
x2 new t-belt/compression/leakdown and then diagnose your probs from there.
Old Jun 6, 2008 | 09:25 AM
28's Avatar
28
Default Re: Just picked up a 94 accord with broken timing belt. what are the chances of bent valves (NeKe1p
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeKe1point0 &raquo;</TD></TR><TR><TD CLASS="quote">
x2 new t-belt/compression/leakdown and then diagnose your probs from there.</TD></TR></TABLE>
I'm not going to spend 5 hours doing a leak down test on a $150 car. I'm just looking for some first hand experience on broken tbelts.
Old Jun 6, 2008 | 09:45 AM
28's Avatar
28
Old Jun 6, 2008 | 11:13 AM
AccordEX1991's Avatar
I bought mine at 180k miles for $150 with a broken belt.
Changed the timing and balance belt and did a compression test. I was lucky to get 200 psi on all 4 cylinders. Now it is &gt;300k miles.
Modified by AccordEX1991 at 2:51 PM 6/6/2008
Old Jun 7, 2008 | 05:00 AM
jamin's Avatar
Default not an accord but another interference repair experience... more
my '88 mazda turbo sohc engine blew its timing belt while i was driving on freeway at 70mph.
after a day of checking why it stopped running i discovered the rotor did not turn while turning the key and hearing the starter turn. so the timing belt was found to be broken and not turning the cam and valves.
anyhow, this engine is supposed to be an interference as our accords.
i seriously expected to have damaged valves after i re-belted it, however to my joy it ran as fine as ever.
recently i replaced timing belt on my accord and its a bit$h compared to mazdas.
Old Jun 7, 2008 | 05:11 AM
YeuEmMaiMai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 28 &raquo;</TD></TR><TR><TD CLASS="quote">I've read a few people on here saying that a lot of cars survive the belt break if it is at low RPMs and someone even said survival is higher on automatics (not sure why)
Its a $150 car I basically bought for scrap, but if its as simple as throwing a T belt on I might do it if my chances are 50/50</TD></TR></TABLE>
once the engine stalls the bottom half actually stops spinning faster than if it were connected to a stick because the tq converter unlocks when the ecu can't run the engine and the trans is no longer connected to the crank causing it to rotate
Old Jun 7, 2008 | 05:13 AM
the majority of us who own honda/acura are smart enough to change the belt when it is due.......and therefore don't have this problem
Cripton805
Jan 9, 2022 07:15 PM
Zeppelin340
Mar 1, 2006 06:18 AM
nyne
Mar 24, 2005 11:33 AM
BoostedB20A
Jan 4, 2004 09:12 AM
im_the_teacher
Nov 15, 2003 11:54 AM
