lighting problem :(
Old Jun 5, 2008 | 10:01 PM
LwdJdmR's Avatar
Default lighting problem :(
so last night i installed my raybrigs on my 96 coupe. and well tonight as i went to turn them on, all of my interior lighting went out. fog lights went out. The amber background on my gauge cluster, the lighting on the climate control. BUT head lights work.. turn signals work.. even the little bulb on the gauge cluster work. What happened?
Old Jun 5, 2008 | 10:05 PM
Eran's Avatar
HT White Ops
Default FV-QR
First try fuse #25 (7.5a) first, and then try the dimmer switch.
How, pray tell did you wire your foglights, and to what did you ground them?
Old Jun 5, 2008 | 10:17 PM
LwdJdmR's Avatar
Default Re: FV-QR (Eran)
ok well ill try the fuse tomorrow. ad i did try the dimmer switch. its gone. hahah
well i used the original harness that came with the fogs. and its grounded all seperatly to the chassi.
Old Jun 5, 2008 | 10:23 PM
Eran's Avatar
HT White Ops
Default FV-QR
Is it the harness that plugs into the two accessory ports on the fusebox or the one that plugs into the headlight switch?
Old Jun 5, 2008 | 10:31 PM
LwdJdmR's Avatar
the one with the two accessory port
Old Jun 8, 2008 | 12:24 AM
LwdJdmR's Avatar
Default Re: FV-QR (LwdJdmR)
bump/
changed the fuse already
and does anyone know the part number for a control lock box for a civic 96-00
Old Jun 9, 2008 | 09:03 PM
LwdJdmR's Avatar
bump.
i rechecked my fuses. re wired my grounds. and still nothing.
Old Jun 9, 2008 | 09:05 PM
Eran's Avatar
HT White Ops
Default FV-QR
Have you checked the dimmer switch?
Old Jun 9, 2008 | 09:10 PM
LwdJdmR's Avatar
what do you mean by that???
Old Jun 9, 2008 | 09:15 PM
Eran's Avatar
HT White Ops
Default FV-QR
I mean, usually when dash lights go out and fuses are fine, then the dimmer switch has gone bad.
Old Jun 9, 2008 | 09:17 PM
LwdJdmR's Avatar
ohhhh i see . . . i will sure check that tomorrow. Thanks Eran
Old Jun 11, 2008 | 09:56 AM
LwdJdmR's Avatar
bump.
can anyone ttell how to check to see if my dimmer switch has gone bad?
Old Jun 11, 2008 | 10:23 AM
Relic1's Avatar
unplug the dimmer switch, jumper the red and black wires together.
turn on your parklights (first position) if the dash lights come on full then the wiring is fine. Turn off the lights.
Remove jumper, plug back in the dimmer, check that dimmer is turned all the way up, turn on lights again, if dash lights remain off then the dimmer is bad.
have you checked all of the fuses? (underdash and underhood)
it sounds like you hooked something up wrong with the fog lights.
Old Jun 11, 2008 | 11:10 AM
LwdJdmR's Avatar
Default Re: (Relic1)
sorry but whats jumper the red and black wire? lol
and yeah i went through all the fuses under the dash and on the engine bay.
and well its the stock harness and well i guess ill pull everything apart again and do it again.
Old Jun 11, 2008 | 11:29 AM
Relic1's Avatar
pull the connector from the dimmer (after pulling the dimmer out of the dash, it pulls right out)
take a paperclip and insert it into the red and black wire locations in the plug.
Old Jun 11, 2008 | 12:17 PM
LwdJdmR's Avatar
does it have to be a paperclip?
cant seem to find one in my house
could i use like speaker wire or something like taht?
Old Jun 11, 2008 | 02:22 PM
riceburnerryan's Avatar
just gotta make a connection between the red and the black wires
keoman
Feb 8, 2014 01:37 PM
powerpro_69
Aug 26, 2009 07:57 AM
EChangApe
May 9, 2009 12:31 AM
LwdJdmR
Lighting
Jun 12, 2008 06:25 PM
Luchini
Dec 3, 2006 08:51 AM
