Rod bearing size selection
Old Jun 5, 2008 | 07:20 PM
lude98SH's Avatar
Default Rod bearing size selection
I have a question regarding rod bearing size selection. I understand that during the final torque you should torque the two sides evenly and use a rod bolt stretch gauge. However before doing this you must select the proper bearing size. In order to get an accurate measurement on the size of the rod you must torque the rod bolts, however since we know that this may be slightly different than using a stretch gauge, how do we do this ? Because different toque on the bolts means possibly different measurements.
Also what is the most accurate way to do this on the mains ?
Also when you use the bolt stretch method should you still oil the threads with either oil or moly lube ?
Old Jun 6, 2008 | 08:13 PM
lude98SH's Avatar
Default Re: Rod bearing size selection (lude98SH)
bump
Old Jun 6, 2008 | 10:59 PM
hybrid2007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Also when you use the bolt stretch method should you still oil the threads with either oil or moly lube ? </TD></TR></TABLE>
It wont make a difference what you use, thats why the stretch method is so much more accurate because it does not rely on the consistancy of friction between each torque.
I'm at the same stage as you with my first build so very interested in the rest of your question being answered
Old Jun 7, 2008 | 02:13 PM
lude98SH's Avatar
Default Re: Rod bearing size selection (hybrid2007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm at the same stage as you with my first build so very interested in the rest of your question being answered </TD></TR></TABLE>
yea i figured it didnt matter.
kornerk12
Jun 29, 2009 08:09 PM
95JDM
Feb 4, 2008 07:39 PM
hi-Powered
11
Apr 20, 2005 09:34 PM
jdm96dc2
Nov 25, 2004 02:13 PM
sir2k
Mar 5, 2003 11:33 PM
