Can I Unplugging ECU connectors?
Can I unplug the 3 harness connections to the ECU without having to reprogram it or the key? I am trying to find the ground wire to the coil of the main relay to put a kill switch on it and would like to probe the wires in the harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30MadMax30 »</TD></TR><TR><TD CLASS="quote">Can I unplug the 3 harness connections to the ECU without having to reprogram it or the key? I am trying to find the ground wire to the coil of the main relay to put a kill switch on it and would like to probe the wires in the harness.</TD></TR></TABLE>
Yes you can unplug the ECU without the need to reprogram anything.
I believe the ECU is plug and play unless it is a new ECU. New ECU's need to be initialized at the dealer.
Someone please correct me if I am wrong here.
Thanks
Thanks
hawj_boi_1
May 30, 2006 05:54 PM
