JDM ef2 front end conversion for ef sedan question...
i'm almost done with the conversion except i ran into a small problem. the headlights won't mount to the usdm core support. the core support sits about an inch back from the headlight mounting tabs. now i've read about a few conversions done, and only one of them used the headlight buckets from the jdm core support. i was under the impression that the only items required were the jdm hood, fenders, bumper, filler, headlights, center grille, and t-bar (all of which i have). is the entire jdm core support a requirement? am i going to have to fab some headlight mounting brackets?
I answered that same question at work on the phone last week.
is the entire jdm core support a requirement? Yes, if you want to do it right and fast. You can fab something up to make it work, I seen people do all kinds of diffrent things to make it work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.ef2sedan »</TD></TR><TR><TD CLASS="quote">I answered that same question at work on the phone last week.
is the entire jdm core support a requirement? Yes, if you want to do it right and fast. You can fab something up to make it work, I seen people do all kinds of diffrent things to make it work.</TD></TR></TABLE>
X2
If you want to be clean, do it the right way. The oem way
X2
thanks for the info but since i couldn't find one, i did it without the jdm bulkhead:
https://honda-tech.com/zerothread?id=2325617
mikecp
Jun 27, 2011 10:52 AM
2 0 3
31
Apr 14, 2004 10:13 PM
xtrafastcivic
Nov 18, 2001 03:09 PM
