Idle and tune up, '92 Accord LX
Old Jun 5, 2008 | 01:29 PM
SpazMan's Avatar
Default Idle and tune up, '92 Accord LX
Hi folks,
I replaced the original cap and rotor on my folks' Accord, and it made an appreciable difference - it'll probably improve the mileage too, I imagine. I'm still confused on how to adjust the idle speed. I need some help, Honda-gurus!
Perhaps I'm thinking too simplistically - I turn the idle screw on the intake, and I expect the idle to rise or fall (CCW - out, more air, higher idle?). All I notice is a sucking sound that I associate with a vacuum leak, the more I turn the screw CCW.
This car has had a 'hard' idle for a long time. What I mean is that there's a lot of sympathetic vibration, more than I would expect even for an older car. At 1200 rpm or so, there's a sympathetic vibration that rattles everything. What would this be? This occurred DIRECTLY after a timing belt change a couple years ago (my folks didn't think to ask the mechanic), so I am thinking the belt is off a tooth. It used to be silky-smooth, when I learned to drive in it in my teens - now that I am a Volvo-freak, I don't drive it much.
Thanks!
Ari
Old Jun 5, 2008 | 03:43 PM
Mr Yamada's Avatar
Default Re: Idle and tune up, '92 Accord LX (SpazMan)
Your statement that the vibration started to happen After the timing belt change points to the balance shafts being out of time
Old Jun 5, 2008 | 04:22 PM
SpazMan's Avatar
Default Re: Idle and tune up, '92 Accord LX (Mr Yamada)
Aha! I though it might be a balancer. Since I'm only familiar with Volvos, please forgive my ignorance as I try to understand:
Is the balance shaft keyed to the timing belt or an accessory belt?
Can I adjust this without removing the timing cover?
This TB only has about 25k on it, so if I have to take it off, shall I put it back on or replace it?
Will it cause damage to continue to use the car like this?
Thanks!
Ari
Jimmy21
Aug 25, 2012 01:37 AM
frankyp
Feb 6, 2008 07:25 PM
unhappy_idle
Feb 13, 2006 06:50 AM
popo
Jan 3, 2005 06:03 PM
1965cat
Sep 28, 2004 08:13 AM
