b series questions...
i don't want to sound totally stupid or nothing.. i come from a ford background.. ie.. mustangs 5.0l and 4.6l.. quit working for the ford dealer.. and got a job at a honda/ acura specialist.. bought a 91 crx.. and have been toying with the idea of doing a b-series swap..
are all the b-series blocks the same deck height?
which would be the best b-series head to start with.. i was thinking that the port sizes might be different from say a b16 to a b18 to a b20
also.. which head has the smallest cc combustion chamber? i was thinking that a b20 with a 16 head would be a great all motor build.. also.. which trans would be the best to go with.. thanks in advance..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez »</TD></TR><TR><TD CLASS="quote">B20/B18A/B is taller than a B18C1 which is taller than a B16/B17.
The B16 and B18C1 heads flow almost identical.</TD></TR></TABLE>
I do concur sir, gibsanez is indeed correct.
B16 head flows slightly better and has better porting / intake options, IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex »</TD></TR><TR><TD CLASS="quote">
B16 head flows slightly better and has better porting / intake options, IMO. </TD></TR></TABLE>
That is basically correct - You can check out more in the All Motor section too
https://honda-tech.com/zeroforum/44
As for the tranny I prefer the GSR for it's "all around" gear ratio. Opposed to the long gears of the LS and ultra short S4C and YS1
