Brake light switch
I have a 1996 honda accord ex with vtech engine.......I have to change the brake light switch in the brake pedal, please help me guys, is that a simple do it yourself job and could you give some insight, thanks in advance..........
A 12mm or 14mm wrench is needed, unplug the old switch, remove the retaining nut, replace the switch, adjust the switch so the plunger turns on the brake lights as the brake pedal arm moves down 5mm from the stop point.
91efbluehatch
Jan 30, 2011 12:56 PM
